Hi all,
Been snooping around as a guest for awhile and now I have decided to become a member n join the happy family =)
Reason why I am posting is that I am looking to buy a used car within the next month after more searching around.
Anyone recommend any shops?
I looked at power road seems ok.
Plus I am still on my probation at work and will finish in 1 month time. Anyone know of any finance places that let you go on finance during probation?
cheers all! look forward to replies from the experienced ones.
https://www.sau.com.au/forums/topic/336449-new/
Yeah the power rd dealer is decent quality some other import dealers just from the top of my head would be SSV on princess hwy and another one on hume hwy I forgot the name but from what ive seen they have decent cars but if you go private make sure you get it checked out or check it out yourself if you know what your looking for.
https://www.sau.com.au/forums/topic/336449-new/#findComment-5441841
I've just bought mine about a month ago :D. I checked out quite a few places when looking for mine. Dealers prices were way above private sale. Ended up buying mine off a member from here. Not sure what state your from but in Vic It was hard to find a good one that was near stock. I looked at around 12 I think in total for private sale. Found problems with almost every one. Then found this one and so far its perfect :). Just take your time, dont rush into buying one straight away.
https://www.sau.com.au/forums/topic/336449-new/#findComment-5441854
If your looking at a skyline, chances are it's been modded even if it looks stock. Save yourself the money (because you will probably end doing the same mods) and buy a lightly modified one off a member on the forum, someone that actually cares for their car!
https://www.sau.com.au/forums/topic/336449-new/#findComment-5441924
Hi Baruna,
Nice to meet you and welcome to the forum.
I brought mine from a private dealer but mine is 100% stock (It's a GTv so no one bothers with them cos they're non turbo)
There is another import yard on Edwardes Road Reservoir, just down from BMSRUS (BMW Wreckers) never dealt with them but I've noticed them a few times when getting parts for my Beamer.
I'd agree with everyone else, check out the For Sales section on the forum. Depending on what you're looking at spending, one of the girls is selling her pearl white R34 for 15,000 from Vic
https://www.sau.com.au/forums/topic/336449-new/#findComment-5442658
Hi Hi everyone,
thanks for all the feedback! its great that the people in this forum are so caring.
Cause I am still on work probation, my banker suggests me I get a loan (as I require some $$$$) after my probation is up.
So...probably won't get one for about a month from now...
Didn't know there was a seller section in this forum as well, thanks for the heads up.
https://www.sau.com.au/forums/topic/336449-new/#findComment-5443872
Hi Hi everyone,
http://www.skylinesaustralia.com/forums/Sa...s-only-f56.html
https://www.sau.com.au/forums/topic/336449-new/#findComment-5444110
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
