Hi All,
i was searching the forum for such information but i can't find it .......
currently i have just completed my rebuild of my RB26 engine, spec are below
RaceTech 86.5 mm piston
TOMEI 1.5mm @ 87mm metal head gasket with oil restrictor
Jun Oil Pump
Balance crank, piston, rod, clutch, main pulley
Refresh Standard Head
HKS step 1 IN/EX 264 cam
Jun Cam gear
BC valve spring
Greddy type 6 throttle intake manifold
SARD 720cc injector
HKS type fuel rail
Tomei Fuel regulator
Garrett GT35R AR1.06 split type
aftermarket ex manifold split type
Tial 44mm ex wastegate
Power FC D Jetro
ETC ETC...
i was hoping to make 550whp - 600whp. i am not sure whether i be at that mark or not.
Would I?
The main question i wan to find out is that would a single SARD / HKS 280lph in tank pump would be sufficient for such targeted 550whp - 600whp.
Would i need 2 Walbro 255lph for such WHP?
IF 2 Walbro would i need to run 2 6AN fuel line to the front of my car? or a single 6AN will do?
So sorry for such question which i believe thousand of ppl have asked . i was hoping to keep my budget low but i believe WHP doesn't come cheap so i would need to optimize my $$$$
Cheers
DC
You will struggle to come close to 600rwhp (440rwkw) on PULP with a GT35.
550rwhp is probably the upper limit there.
If you want a jap pump, a nismo or similar will be fine.
Otherwise a big bosch will also do. Forget wasting time with walbro fuel pumps.
From what I know the good jap pumps (nismo, sard etc) run out of puff at the 450rwkw mark. Have seen a couple of setups with that sort of number who could not go further due to their fuel system.
one pump fuel you should be able to see you max out the 35R. a Nismo/Tomei replacement pump or a single Bosch 044, thought thats getting to the point where a surge tank isnt a bad idea.
wow i was tired when i posted that.
one pump should be enough to see you max out the 35R. a Nismo/Tomei replacement pump or a single Bosch 044, thought thats getting to the point where a surge tank isnt a bad idea.
How about the bosch 040 and 044 fuel pumps, when do they normally run out of puff?
wanted to put the surge tank but ust afraid that the whole car will smell like fuel.......
its not really the surge tank that makes the smell, more the fittings associated with it.
my engine build is going for around 600hp as well and ill be using twin pumps and a surge tank, ill be using all solid steel lines instead of braided to lessen the smell of fuel.
  • 4 weeks later...
Mount it under the car.
2x Bosch 044's will suit you well and provide more than adequate fuel, use a low psi lifter pump like a Carter Gold and a 2.5lt surge tank will fit.
I have run this system on my car for over 2 years, speedflow fittings all around and braided lines, I never smell fuel however the Bosch 044's do get noisy when the fuel gets hot.
Also beware of ebay and people trying to sell knock-off 044's you want the Genuine Bosch not some chinese copy.
In an rb25 R33 we made 604rwhp on a GT35R with 1.06AR, but had to use E85 to get it there. That is the highest we have had from a GT35R. The same car makes 535hp on 21psi on pump.
We are making over 1200rwhp+ with 2x GT35R's on a 20B Triple rotor.
Initial run in tune netted just under 1000rwhp @ only 21psi.
We have pushed the GT35R's to 38psi, figure was good but not giving away any secrets, car is in the 7 second quarter mile club now... only running 28x9 tyres and still untubbed.
This is tuning with the big boys though... M800 with 90% Methanol mix.
Edited by Parag0n
If you don't want to run a surge tank, try a 040 intank then an 044 in series... mount the 044 under the car and use the stock fuel lines. I'd also suggest running the 044 from a speed controller/pwm.
Or use your stock fuel pump to feed an undercar surge tank, and use a single good quality fuel pump such as a weldon a2005-a or 2015-a.
Have you used a Weldon pump; they look awesome!
