in what situation would you use 5-40 over 10-40?
rb25det
Doesn't matter much. They're very similar, and let's face it companies are more likely to round off to a factor of 5 rather than naming products 3w, 4w, 5w, 6w, 7w etc. So they might be very close.
Also since the w40 is common the viscosities of the two oils are constantly approaching eachother as they warm up.
Technically, if you're in a colder area the 5w might make it better for cold starts, but the difference will likely be negligible compared to the different quality 10w40's you find (eg: magnatec vs sougi).
On that SC article, it is a very interesting experiment but grossly oversimplifies an engine. Firstly, it is poor to compare oils of different viscosity because the thinner oils should have different film breaking characteristics to thicker oils (of almost identical composition) which would influence their result. Further, your car is not a spinning piece of metal grinding a bearing, it's a complicated closed system requiring oil transport.
The oil needs to be thick enough for protection and thin enough for drainage past the cylinders into the sump and adequately lubricate ALL parts of the engine+turbo. Interestingly viscosity is quite different to surface tension, which is what was on test here (trying to make the film break). The way the oil was cracked in processing, the additives used, the means of synthetic manufacture and the particular molecules used in production all change the surface tension the oil has.
The idea of testing oils is interesting and difficult. An engine oil may be perfect in every way except drainage and hence is useless. The results from the SC test are very interesting, but without knowing the particular chemical make up of the oils and allowing massive variables like viscosity, the results are pretty useless. And since the test has barely anything to do with an engine, it's even less useful for oil choice.
Edited by Galois
wow i just found this on the internet... very interesting!! tell me what you think!
http://www.animegame.com/cars/Oil%20Tests.pdf
Very interesting topic on all the major brands of oils , especially some big names which aren't as really good as they claim to be ! I use Penrite Sin 5 in my skyline , never had any problems & shows it is one of the top quality performing oils on the market. Test results now prove it . Good job Penrite :P
Very interesting topic on all the major brands of oils , especially some big names which aren't as really good as they claim to be ! I use Penrite Sin 5 in my skyline , never had any problems & shows it is one of the top quality performing oils on the market. Test results now prove it . Good job Penrite :D
This test in SC mag was published back in March 2006 and has been the subject of intense discussion in SAU threads (just look through some of the recent posts.) SC mag did a follow up article after protests and criticisms by the companies whose oils didn't rate so well - I gather the main complaint was that the test wasn't comprehensive enough to provide a valid comparison of the overall qualities of each oil tested, although they did point out the limitations of the test in their intro.
If you accept that loading up a solid roller bearing onto a spinning metal wheel in an oil bath can represent wear between the moving parts of an engine, then you may be inclinded to draw the implied conclusions when choosing your oil. I have to admit that it seemed a good enough reason for me to change to Penrite Sin 5w-60 or Sin 0w-50.
were should the oil pressure gauge be siting on start up and then when warm, since ive changed my oil it been different, sits between 0 and 4, sometimes at 4.
Any info appreciated.
depends on the oil viscosity and how warm the engine is (or how cold it is outside on cold startup)
eg. I think normal is around 2 when completely warmed up. Also on cold startup, if it's a cold morning it should be between 5-7 (higher is better as the oil is thick when cold) Having said that, the stock oil pressure gauges are notorious for playing up... I had mine take a dive to 1 or so for a while but has since fixed itself.
  • Like 1
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
