6bolt drive shafts $100
s14 nismo 2way lsd centre,with 6 bolt half shafts $400
5 bolt drive shafts $80
r32 gtst rear 5stud hubs,brakes,hand brake set up $250
r32 rear cradle with all arms $100
r32 lsd diff $100
r32 clutch pedal, clutch master cylinder,slave cylinder,and all the lines between $200
r32 manual brake pedal $40
r32 brake booster and master cylinder$80
r32 excelerator pedal and cable $40
r32 charcol canister$20
rb20 top timeing belt cover $10
r32 hand brake $40
r32 heater core and evaporator assbly $100
brand new walker rear cannon 2ich inlet 4ich out let $50
brand new walker cat 2ich in 2ich out $50
brand new walker middle muffler 2inch in 2ich out $50
rb25 cam covers$40
rb25 coilpack cover$10
rb25 top timeing belt cover$10
r32 climate control unit$50
r32 drivers side window switch assmbly $50
rb25 crank angle sensor$50
rb25 intake manifold,bare top and bottom half$40
pioneer mini disc player$40
rb20 engine,coilpack,loom$150
r32 steering colum with ignition barrel and key$50
r32 fiber glass rear pods,small crak in one$40
rb20 hicus power steering pump $40
rb20 afm green label $50
r32 front wiper arms$15 for the pair
r32 front rotors $30pair
rb20 egine mounts$30pair
rb20 coil pack brakets$20
rb20 back plate,that goes between box and motor$10
rb20 red top cam covers and top timeing belt cover painted red with the lines sanded back$60
located strathalbyn SA 0431 540 141
can post some of the small items
hey mate, might be interested in the r32 gtst rear 5stud hubs,brakes,hand brake set up and possibly the charcol canister aswell. Im in Rostrevor, Strathalbyn is a little far, do you ever come abit closer?
yeah dude come to town a fair bit.i can meat you at mt barker or something or when i come to town next ill bring them
Hi mate im interested in the brake master n booster, is it in good working order ie no leaks? can u post to nsw 2464?
hey dude yeh its in good order,postage is $30buks,let me no if you are wanting it still
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
