hey for those who have bought and installed a exhaust system on there skyline im sort of interested in getting one but just need to ask in general how much it cost you to put the system onto the car (how much the mech charged), cheers
https://www.sau.com.au/forums/topic/337743-exhaust-installtion-prices-question/
Done this many a time now.
Jack the car up, undo all bolts from turbo back. I had old one off and new one on within the hour.
Be careful where you go if you choose to go the mechanic route, I had an estimated quote of 3hrs labor at $110 per hour to fit a turbo back exhaust!!
If you've got the tools and a free afternoon save yourself the cash :D
EDIT: Cass, fit my exhaust to your car already, want to see how it goes for you ! :)
EDIT: Cass, fit my exhaust to your car already, want to see how it goes for you ! ;)
Need to find some gaskets first. I'm not like my brother and can tolerate driving around without exhaust gaskets for any longer than the time it takes me to drive around the block :(
Cat-back? Turbo-back?
If it's cat-back it's quite easy to do...
Agree. I put a new cat and a cat-back exhaust onto my gtr whilst it was on the ground in 30mins... Couldnt be arsed jacking it up :blink:
I did a full dump, cat and cat back on my r33 gtst in about 2 hours including time for the WD40 to sink in on the studs.
Cost - nothing! Did it myself without much pain :P
Need to find some gaskets first. I'm not like my brother and can tolerate driving around without exhaust gaskets for any longer than the time it takes me to drive around the block :)
Exhaust gasket cement.
um lols. i just cleaned the metal between the rear muffler and the piping forward and whacked it back together.
fiiiiine i'll get some cement and do it properlike
Using the theory that a leaking exhaust flows better than one with no leaks? :blink:
I used gaskets and cement, but originally when I installed it with AbboBob (ex SAU president), he said you can get away with vasalene if the exhausts fit up close enough, the vasalene will attract some of the carbon from the exhaust, the vasalene will then pull the carbon into any depresions and keep a hole sealed up (assuming it is only a small hole).
It worked for a year, untill I was bored and randomly decided to cement it up, I was skeptical at first but it worked for a year that I know of.
Best to do it properly though from the beginning, a good job will save you time in the long run
Call an exhaust shop.. Tell them what your interested in.. Get a price.. done..
YUp this is the easiest, and sometimes even the cheaper alternative, especially when you break the dump pipe/turbo exhaust flange bolts in the turbo flange and depending how unlucky you are you could be up for a turbo out job just to be able to drill the bolts out
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
