Hi all,
I've recently been lucky or maybe unlucky to some. My dear brother has purchased for me an R32 gtr from an auction house in QLD and has repaired all panel work and resprayed it as well for me. It's a very nice gift from him indeed but he said that the car's alignment is off so I will need to re get it done. Thinking that this was all I needed to get done before I could get it re registered in NSW and come along to the 10/10/10 cruise with SAU members but this no longer seems to be the case.
First I got it to the wheel alignment shop, they put it on the hoist and straight away they said that if you want your car to drive straight you need to replace this left hand side castor rod as it was bent. So no problem I set off and found myself some nice adjustable cusco castor rods, i installed them then went back to the wheel alignment shop. They spent some time adjusting and adjusting then they said, somethings not right... the caster seems to be fine but because they couldn't really adjust much camber with the stock camber arms, they said that the car will still pull to the left due to the camber on the left hand side although it will be much better than it would be before. So again slightly confused as to why but no problem I set off to go get those pivoting adjustable camber arms from UAS then went back and got them installed and to get another alignment done. Thinking this was going to be all good and having the thought of the car driving true and straight again was making me smile. But then..... the camber got worse but the castor got better! They weren't sure either because the after market camber arms were in fact shorter therefore logically the problem with having positive camber of the left handside should of been corrected. So currently now were at a point that we think the car is bent on the left hand side some where. I've had a suggestion of going to get it on a chassis jig test and see whether the car is true and straight, so I went of to a local Body repairer panel beater but after hearing it was a japanese import they were reluctant to touch it and they were talking big numbers already. What do you guys suggest? is there a chassis straightening place you guys recommend in sydney, hopefully south west but if not no problem? Below are the results from the wheel alignment..
After installing castor rods (After installing camber arms):
Rear axle
Camber
Left: -2.03 (-2.06)
Right: 0.04 (-0.26)
Toe
Left: -0.12 (-3.9)
Right: 0.13 (0.7)
Front axle
Castor
Left: 2.22 (5.34)
Right: 4.22 (6.01)
Camber
Left: 0.08 (0.21)
Right: -1.59 (-0.23)
Toe
Left: 0.41 (0.3)
Right: 0.52 (3.1)
Also to avoid making another post in this section, i thought i might as well add it in here since its already a long post. Second problem that was really conscerning me was the brake pedal. It felt really mushy, light and not very good a braking so I did the first check of looking at the pads to see if there were any left. No problem pads were fine as well as discs. Next check was to check fluid levels, was a bit low, so got them bled and refilled. This actually help the pedal feel alot more but honestly i don't think this is the way its suppose to feel, its still got that initial slow down bite as soon as you step on it but then it dosen't really do too much more after that and if you want to wipe down a bit of speed you pretty much have to put that brake pedal down to the metal. I've had thoughts that it could be the brake master cylinder, any other thoughts?
I'd like to thank you for taking the time and reading the post and I also will appreciate any input. Thank you
Cheers,
Ken
https://www.sau.com.au/forums/topic/337783-advice-needed/
  • 4 weeks later...
check that they are tight,
any good mechanic can rebuild calipers, its just new seals and pulling apart cleaning and reassembling.
if your car is bent just get adjustable everything so you get the alignment etc good, much cheaper then trying to straighten the chassis
https://www.sau.com.au/forums/topic/337783-advice-needed/#findComment-5518699
if the car is bent, which it sounds like it probably is if it was bought damaged from an auction............... sell it and don't tell anyone
calipers are fairly easy to rebuild yourself, i just did mine on the weekend.
protip if you decide you're going to paint the calipers too, do the painting on the car because proper brake caliper paint only cures properly at high temps so it might feel dry when you touch it but you make a mess when you pick it up
https://www.sau.com.au/forums/topic/337783-advice-needed/#findComment-5518736
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
