Ahhh but who says I'm right? :D
well atleast you agreed...what i say is usually questionable...but nice to know that what i think and what i direct others are in the right direction... ;)
  • 10 months later...
  • Replies 73
Hey guys. I've never changed oil on a turbo or perfomance car ever.
Was wondering is it the same as any other normal car?
Would yo use an oil flush let it run then drain it all out? Or would that not be advisable? A bit worried as I'm running a ball bearing turbo? Would this pose any problems?
From memory:
Nissan recommend 7.5w-30 (in JAPAN) on new engines. Probably to help fuel consumption.
I'd go with 5w-40 (Shell Ultra or Fuchs or Motul if you can afford it)
NISMO recommend 10w-60 for track work.
The RB25DET is 12 years old, not rebuilt and ~150,000km old. The SR20DET is 13 years old, not rebuilt and ~90,000km old. Neither blow smoke. Both have excellent compression and make the power I'd be expecting from them.I just find the thinner oils break down far quicker and end up thin and watery by the next oil change. The slightly thicker oil gives me a quieter engine and I drain almost exactly what I put into them out at the next oil change. A good number of 10W40 oils contain a lot of friction modifiers to achieve the desired viscosity, they're not fantastic for the engine.
Yeah the oil seems thin when it comes out cause it is warm.
If it is much thinner then it is diluted with a LOT of fuel - doubtful.
I've tested viscosity of a few oils new and used from my car after 7500km and there is a bees dick in them. Used oils are slightly thinner - a few percent which was probably fuel.
FWIW viscosity at 99°C in Cst
crankcase oil SAE 20 >>>>> 5.7-9.6
crankcase oil SAE 30 >>>>> 9.6-12.9
crankcase oil SAE 40 >>>>> 12.9-16.8
crankcase oil SAE 50 >>>>> 16.8-22.7
Edited by simpletool
Fill til it comes out the filler plug...that's what it's there for. For obvious reasons you won't be able to put any more in!!!
laugh it up when i worked at ford an apprentice did just this!
fill it up you said aye
he filled it alright bout 25litres of oil i think in an xt falcon
:blink:
I'm surprised to hear so much variation here. My R33 GTR took 4 litres, mabe a bit over, but nowhere near 5L. Do they all have different sumps? Is there a benefit to overfilling it some?
what the.. my 34s rb25de only takes about 3.5L...
i use motul turbolight 10w40 btw
I'm using Royal Purple 10W40
Sorry about the multiple posts, I kept getting an error message.
Edited by Ishman
ive used 2 different oils now, motul 4100? turbolight 10 40 and before that used to use mobil 1 5-50
both only used 3.5L (not even close to 4)
does this include a filter change?? i always get just under 5 in and its on the full line of the dip stick. maybe 200ml left in the bottle. im slowly filling one bottle with all the left overs of other changes :nyaanyaa:
If you do oil filter change, drain the sump very well and pour 5L of new engine oil in. Make sure the engine is warm to allow gunk to all come out before draining.
  • 1 month later...
was just fine, but i havent seen any difference since using turbolight .. and its much cheaper
3.5 liters in an rb?
doing it wrong
by the book it's like 4.7l or something
just put 5 liters in, saves wasting it and isn't going to hurt your car at all. it will help stop oil starvation if you drive around the streets like a mad flamin mongrel
doing it wrong
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
