Hey people,
Seeing how the aussie dollar is doing so well I have been looking on summit racing america lately and been thinking of getting nitrous. I have been doing some reading and see the key things to run a motor with a wet nos setup is
  • Retarded timing
  • Decreased sparkplug gap (recommended something like 0.7mm gap, I currently use 0.9mm gap
  • Also recommend colder plugs.. I run NGK copper plugs with a 7 heat range
  • fuel injection into the plenum, cant find much info on how this works
Now im currently building an RB30DET with forged rods, pistion 9:1 compression, RB25 Head, with cams, and mild porting. All the wet kits im seeing on the net are for carby cars. Are these kits suitable? Here is a link http://www.summitracing.com/parts/NOS-05101NOS/
And I just cant find info on where the fuel comes from. Im making a 2L surge tank, I havent welded any bungs on yet but should I put one in to allow for another fuel outlet?
Ok, so I understand the kits have a Master switch to turn nitrous on and off, and a micro switch on the accelerator while on 100% throttle to activate the nos and fuel solenoids to inject the stuff...
EDIT: I forgot to mention, I also have a water meth kit on the car, which im assuming will only enhance the operation of the nos, due to it heating the motor up, the water meth should cool it a bit yeah?
Ok so a turbo motor wants timing, and a nos fed motor wants retard timing, is there a way around this?
The car is a rare weekend warrior and the nos will only be for drag days, just to get that but past a 12 second pass into the 11's. The car has a Vipec ecu, and I'm just wondering about how it will cope with the nos injected... My thoughts are, its going to need to be tuned for nos.. but then what about when its not being used? Does anyone know if vipecs can have two tunes stored to them? Ill have to talk to my tuner a bit more about this, but any info you guys can enlighten me on would be greatly appreciated. It's hard to find info on the net about it because its always carby cars they use it on that dont need ecu tuning!
Thanks guys
Edited by choku_dori
https://www.sau.com.au/forums/topic/337841-nitrous-kits/
Negative, completely different kit/setup.
You want a universal wet kit made for a fuel injected car, not a carby. You want something like this:
http://www.holley.com/05130NOS.asp
It is a simple wet kit that is a simple bolt in job, put in the corect size jets and you are done. You don't need to tune for the nitrous unless you are trying to get every bit of performance out of it. Just make sure that the jets you are using are not going to cause the car to ping on the tune that is in the car. You can run dual maps but that is more hassel and not needed for what you want.
You are a bit confused by it all because you have been looking at carby kits (hence your points about retarding the timing and injecting the fuel into the plenum).
Read through these instructions so you get a good understanding of how a universal wet kit works in a EFI car:
http://www.holley.com/data/Products/Technical/199R10295.pdf
However if you want the good stuff, these kits are ment to be some of the best.
http://www.noswizard.com/
Start doing some research on here regarding pulsoids.
http://forum.nitrous-advice.org/
There is a lot to it and I can give you as much help as what I have researched and experienced, but my knowledge is also limited compared to some of the guys on here that have been running nitrous for years.
Unfortunately there is a lot of people on here that havn't had experience with it and have been fed second hand knowledge which is incorrect, so you will most likely hear a lot of negative comments regarding nitrous.
Also you will not need to install the microswitch on the throttle body, the Vipec can switch the solenoids on electronically through a voltage signal from the TPS instead of a mechanical microswitch detecting wide open throttle. This also allows you to select which gears are locked out for the nitrous and what rpm the nitrous activates and deactivates. (Hitting a rev limiter with nitrous engaged is one of the worst things you can do so the rpm limits are VERY handy!).
If you do your research, aren't greedy with running big jets and have a few safety precuations installed to make it run safely you will get good use out of it and won't experience some of the horrors which are assosiated with nitrous.
Good luck with it :(
Edited by PM-R33
https://www.sau.com.au/forums/topic/337841-nitrous-kits/#findComment-5460961
Thankyou, didn't expect such a useful post. Ill have a read of the websites a bit better tomorrow when I'm awake, but this definately looks like a good way to get that extra bit of speed down the quater mile :P Im sure I'll be in contact with you again mate.
https://www.sau.com.au/forums/topic/337841-nitrous-kits/#findComment-5461040
The Vipec can also switch maps very easily, and by that, I mean switch maps that a tuned specific to Nitrous.
Just like if you install Dip switches on your dash to some inputs. This is to allow you to switch to other maps (for different fuel, rookie driver etc), and in the N02 case, the Vipec "knows" when these special maps are needed and will switch to them. (ie, When the nitrous is activated).
https://www.sau.com.au/forums/topic/337841-nitrous-kits/#findComment-5462006
  • 5 months later...
The best are ment to be the pulsoids from Noswizard http://www.noswizard.com/product_list.php?id=2
Having said that though, the NOS ones are good for your average person. If you were using it a lot and had quite an extreme setup than yeah I would probably go with the pulsoids.
If one of my solenoids ever fails i'll probably replace it with a pulsoid just to give it a go.
https://www.sau.com.au/forums/topic/337841-nitrous-kits/#findComment-5696839
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
