hi all
wondering if this thermo wrap is actualy any good? seen a few cars supporting it
would like to head from anyone whos done it, brands to stay clear of, power increases, or any other bits to add to the melting pot :P
im unsure as to how it works on exhaust... is it to keen the head in the manifold/pipes, to reduce heat soak to pre engine bits, or are there other reason...
also i rarely see intercooler pipes with any on it...
:blink:
https://www.sau.com.au/forums/topic/337860-thermo-wrap-is-it-actualy-decent/
if your exhaust is mild steel then stay away from wrapping it. seen a few cases of front pipes rusting out fairly quickly(even to the point of my mates 13BT front pipe collapsing in on itself).
Ceramic coating is the way to go for ultimate heat protection
Wats the reasoning for such serious fast rust??
I think my catback is but 99% of front pipes are stainless... Much reason u wd do the catback anyway??
hi all
:blink:
Heat wrap/ lagging is predominantly used to protect surrounding components from heat damage in the case of exhausts. There is an amount of evidence to show keeping the heat in the pipes also improves gas flow due to higher temp as opposed to cooling (shrinking) gas where heat is shed. I'd stay away from heat wrapping intercooler pipes, unless they were routed near the exhaust, the pipe will shed heat better without it.
I'm just using steam pipe lagging on my dump & front pipe, it was easily available to me through work, and performs the same as any other type of "specialist " heat wraps for cars.
Resist the temptation to paint it though, you will be subjected to a life of burning paint fumes until you finally give up and remove it; as my friend found out...
+1 with Big Fella on mild steel, use only on stainless.
my understanding was that it was more the domain of cars with high mounts and big tuned length manifolds that put a lot of the 'hot bits' quite high up in the engine bay etc - and obviously cars that are doing serious work. all the reasons above obviously apply. other things can be as simple as it protects the paint work from being damaged from heat exposure as well as other plastic and rubber bits that live in engine bays.
i guess there would be an arguement that it would keep underbonnet temps down on a stock car, but i think a simple cold air feed would probably do more and be better at overcoming heatsoak.
the stuff is also frightfully expensive! i think your money is better spent elsewhere unless you're planning on a 35/40 highmounted to a 6boost, but if you ARE then go for it!
for the cost, you may as well get the stock cast manifold hpc coated inside and out
like some ppl said, it keeps the heat in = larger volume of gas = faster gas flow
will also cool down your engine bay no end
get your dump done at the same time, thats about the only sections to worry about getting it done to
So blue mesh would be a better option roo??
:D
So it would do more holding heat in, than protecting it in i/c piping??
Im not in the market for it, just saw a bit if it and wanted to know more about it,
And yes yes its not cheap!
It adds 10+kw. Tough as >_<
ceramic coating and heat wrapping do 2 very different things and you need to be aware of which one you are chasing.
Ceramic coating is a heat barrier that inhibits heat transfer to other parts of the engine (ie exhaust manifold to cylinder head) because, as we all know, heat = less power (inside the air pump we call an engine, anyway) Used on the entire exhaust side of the engine process, it forces the exhaust to carry away "waste" heat and not let it soak into the engine, whereby forcing undue load on to the heat exchange cuircuit.
Thermo wrapping of exhausts is a different kettle of fish altogether, and especially on race cars, is not there to stop the heat being absorbed into other engine components, its to keep the heat in the pipes. If it was to stop radiation then simple waffle shields would be used (like on factory set ups) combined with an efficient CAI setup.
The main reason for its use is because a gas's volume will increase in proportion to its temperature, which in turn increases its pressure. Exactly how much benefit this would provide in a turbo charged car I am yet to be convinced of, but in a NA application, when combined with a free flowing exhauist and a well designed set of extractors, it increases pulse scavenging by a huge amount, which in turn provides many ecomony and power advantages.
is this to say you are not suppose to ceramic coat and thermal wrap the entire exhaust side?
because wouldnt it be a double hit if you do a coat and a wrap?
wow quite a can of worms ive opened here :blink:
so are we kinda agreeing that its not worthy of putting on an exhaust of a street style car??
i was kinda looking at ways to stop heat soaking into the intercooler pipes and alike (pre-engine components obviously)...
would you attack this by stopping heat coming off the exhaust, and leaving the cooler alone, or would you wrap the cooler pipes... while locking in what heat is there while your at it...
No, definitely worth putting an exhaust on a street car.
If you want to insulate pipework post intercooler, go for it, I'd resist insulating pre intercooler; you'll be able to shed some heat there.
Just zorst manifold and dump pipe...?? My cat back isnt stainless so more money than its worth there... And with cooler i was just thinking as it came back into engine bay...
Do u just do a single layer or over lap effectivly giving u double layering
On mine; I insulated Dump, and front pipe, leaving cat exposed, with a 50% overlap, this took me to level with the back seat. Again, you mightn't want to get that excited, my wrap was free :blink: . Do your exhaust manifold if you like, I'd be happy with the factory heat shield in most cases.
Hey,Chef ,I had the same doubt as you so my cheap ass solution was the ACL heat shield, still hot around but not direct radiant from my Xforce ss dump pipe,did it about 8 months ago ,so far so good ...
Cost me $45 +$5 on ss ties, you can see it in the second pic ...
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
