hey guys,
I've decided to pack up shop and head overseas for work and study. So i'm selling my car, and all parts that i had built up ready to upgrade the beast.
Photos will be coming tonight, but here's the list as it stands now.
Hypergear High-Flowed RB25 Turbo (i believe its a Tr43?), $500
ECR33 PowerFC ECU, $900
Z32 AFM with plug, $200
R34 SMIC, $150
8 x S15 (480cc) injectors (on s15 rails), $400
R33 Side Skirts (white), $120
R33 S2 Front Seats with rails, $100
Apexi power intake (pod filter, barely used), $50
HKS mushroom pod filter, $50
R33 weather shields, no clips, $50
That's all I can think of for now, I'll add more as i go through my garage.
As stated, also selling the car :Ohere
Pics will be added tonight.
I can be contacted via PM, or shoot me a msg 0415 795 920
cheers
https://www.sau.com.au/forums/topic/337896-quarkguns-liquidation-sale/
Hey mate,
The power intake fit the r33 intake fine, i didn't need an adapter to fit it anyway. Not sure about the s15 though... if the intake size was the same then it should fit
hey mate, yeah its a direct replacement for rb25det engine, but i believe you need to replace the oil feed line (~$50) or remove the restrictor in the stock oil line. that's according to my research, i never went ahead with installation so i didnt get around to getting a new oil line.
A couple of ppl have asked me about the turbo, so FYI,
The turbo was bought of a fellow sau member, who told me that the turbo had done only 3000kms, so still pretty young. I'll post up pics tonight to show condition.
Hey Guys,
here are the pics, any questions pls let me know.
Turbo:
AFM:
S15 INJECTORS:
HKS POD:
APEXI POD:
POWER FC:
DUAL GAUGE PILLAR MOUNT (shown with shadowed gauges)
Only test fitted, but sits perfectly flush on the r33
AUTOGAUGE SMOKED LENS GAUGES (BOOST-PSI & AIR/FUEL RATIO)
USB CONSULT CABLE:
PINEAPPLES (Subframe Alignment Kit):
GREDDY GAUGE PILLAR MOUNT:
SIDE SKIRTS:
FRONT GRILLE:
Added some parts:
Front Grille, $50
Greddy Gauge Mount, $30
Pineapples, brand new unused, $100 ($137 from whiteline)
USB Consult Cable + my nisdatascan license, $80
AutoGauge Gauges, new and unused, includes all necessary wiring, $25 each
Dual Pillar Gauge Mount, $30
I think that's about it. Thanks guys.
Hi dude, very interested in the z32 and injectors.
Have you had the injectors flow tested, and what can you tell me about them?
I was going to SMS you but it's 1am an I didn't wanna wake you up.
I'm on the gold coast, could you arrange for postage? I don't need the rails.
Also interested in the gauges and dual gauge pillar mount. What psi does it read up to?
My number is 0421517163 if u prefer SMS :blink:
i've sent you a PM
Guys, i need to issue a clarification on the turbo.
I've spoken with Stao from Hypergear (thanks Stao) in order to properly identify the turbo. he informed me that it is not suited for a rb25, rather it is a 2006 TR43 turbo suited for RB/SR20, and will produce approx 230rwkw. So, i'm glad I found that out before selling it, but yeah, i'm annoyed that i was sold the wrong turbo to begin with.
So, if anyone wants to upgrade their r32, silvia, 180sx or 200sx turbo, or your fully sick pulsar!, then this one is a good buy :rofl:
Price stands at $500
Thanks.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
