maybe one day i'll make the move! i do like steak..
My point is only if you have two to chose from in the beginning steer the other way.
If its in there already and its working for you dont bother changing.
Kristafa: did you get your AWD to work with yours, and if so, then how?
I have pretty much the exact same problems PM-R33, 18L/100 sucks, so does having to replace completely carbon fouled plugs every 10000km. My smokescreens are incredible on WOT, good for tailgaters though LOL.
I have pretty much the exact same problems PM-R33 HAD, 18L/100 sucks, so does having to replace completely carbon fouled plugs every 10000km. My smokescreens are incredible on WOT, good for tailgaters though LOL.
:laugh:
Edited by PM-R33
Dude thats just a shit tune. I know microtech's are a bit ancient compared to some other stuff but you can still get them to work well with a good tune.
I have none of these symptoms, and as before i average 13L/100km give or take. Guess i have a good tune :P
Mine is in a RWD bmw..
Link G4/Vipec V44, Haltech E11V2
Don't touch the Microtech, you will regret buying it, I did...
I regret using a power fc lol they had there place 10 years ago. I have not missed my power fc one bit since it went to a new owner.
For the price you can't go wrong with the ViPec. As with Phil i totally agree.
Fuel cut for rpm limiter on power fc :down:
Also did i mention i hate air flow metre's? You will skip that issue with micro tech but definitely wouldn't recommend going down that path of essentially using a game boy advance to run your car
Edited by Weapon
If you have ever seen one with a "good" tune please let me know, because I know of 3 other cars with Microtechs locally which have the exact same symptoms.
This is also running a tune from CRD.
whats your altitude?
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
