Hey all, done a lot of research about which oil pump to use, then found this:
http://cgi.ebay.com.au/NISSAN-RB-SERIES-HI...=item20b3e94e13
Anyone seen/heard of/used one of these??? If so, good or complete sh!t???
Looks very similar to a G-reddy/nismo style pump.
Obviously would love to get a Tomei, but cannot afford one.
Any info on these good or bad would be very helpful.
Thanks, Dave.
https://www.sau.com.au/forums/topic/338110-rb-high-flow-oil-pump-no-brand/
i was about to ask a similar question as i just found this one. http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...e=STRK:MEWAX:IT
possibly a cheap batch from overseas or something local that would be worthwhile? otherwise i'm considering some billet gears for $370
Hmm, Nismo, Jun, Nitto etc all use the shark-fin outer. This pump looks very similar to Nitto and G-reddy pumps, as they have a similar 8-bolt backing plate flange.
Nitto Pump:
Key I guess is the width of the gears (std 11mm) and material.
Is there noone that has used these pumps before?
log in - yea I saw that one too, looks like the same pump - they look ok, but I guess that means f*ck all. Where can you get billet gears for $370?
just had a look and the company is no longer around but JPC sells them for $350
^^ lol why would anyone touch it with their dick?
so you could f*ck it before it has the chance to f*ck your engine.
why would anyone ever take a risk with such a critical engine component. It will end up bad money chasing bad money.
wow ebay can sell some pritty crapy stuff, but if its cheap enough than why not have a go..... when your talking about somthing like a deck chair or a cheap socket set..... but somthing like a Oil pump for a freshly built motor..... Dude just buy a nitto.......
If in fact it is a proper billet oil pump the same as a JUN/Tomei/Nitto then awesome.
Because it would be about Fu(king time good pumps were sold for a realistic price.
Whats interesting is the cost of a 2JZGTE genuine pump and their actual spec. Plus their reliability is second to none. How much? $300 delivered from USA.
Yea, it's quite funny, all of you have just replied exactly what I have gone over in my head - why take a risk like that with an untested product? But then, if it is modeled off a Nitto pump, and has the same quality gears, at a price like that, then how can you go wrong?
Tough decision, I have asked all who are selling them on e-bay to elaborate on the gear size/material so will see what they have to say.
I have pretty much made up my mind on the billet gears for my N1 pump though - roughly the same price for known quality results.
But as N1GTR said, there is no reason we should be able to get a quality pump at a reasonable price.
if you think these big companies make the stuff in house then your off with the fairies, there is quite a possibility it is straight out the back door of the same factory the others are from. I buy cranks from a company that supplies a few majors @ 1/4 the price.. there are other options you just need to validate its source.
if some-one buys it in vic im happy to compare the gearset to a genuine GREDDY item, it would be worth getting the gearset tested.
^^ Agreed..and after comparing all pictures of the genuine 'nitto ' casting and these ones...front and back looks identical everywhere and the only difference i
can see is the rear plate is dull compared to the genuine nitto & phillips head screws used instead of hex.
In fact im going to buy one and get the gears tested for material & hardness.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
