Hey all, other night discovered this new place on Westall road with a few mates from SAU.
its called RaceSimCentre its got some hardcore racing simulators and they were pretty epic compared to the real thing.
All their circuits are real ones from around the world which have all been Laser scanned accurate to within 2mm of the real thing.
If some people are interested on going down i suggest you check it out as the guy who runs the joint will give you a good 15minutes free to give it a go.
Definatly worth a look at and might even make an event to cruise down there sometime soon and play for a few hours.
there located on 127 Westall Rd, Clayton South
check out their website for people interested who want more info http://www.racesimcentre.com.au/
https://www.sau.com.au/forums/topic/338123-racesimcentre/
  • Replies 73
Posted Images
Looks like they only use G25 / G27 steering wheels anyways which I already got, and a big screen to play on.. only thing im missing at home is the racing seat but some people just make rigs up
would be fun to play with mates tho, or just do DECA :P
https://www.sau.com.au/forums/topic/338123-racesimcentre/#findComment-5466226
Just got a 49.77 on lime rock in the radical. Setting up car to go. For the world record lol! Love this game
Charles whoever was in the left seat when u guys went last night wasn't pushing it hard lol. Did 4 seconds better on the cold lap :mad: haha
https://www.sau.com.au/forums/topic/338123-racesimcentre/#findComment-5473130
LOL WTF, how did you know I went? And that was my mate in the left side, I was on right lol.
Lime rock... is that the track that he recommends on the free 15mins? If so, I did it in 55.xx in the Radical (first time).
I thought that joint is pretty cool, but it would be awesome if they had imports and drift tracks lol.
https://www.sau.com.au/forums/topic/338123-racesimcentre/#findComment-5473218
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
