Crap night, ran badly, at home and in bed by 8:30... The weather turned nasty and sprayed on us. It was sooooo packed too. Two dudes with 32 R's ran low 11's. BTW, thanks to the dude with 32 GTS that let me sneak in - if you're on here!
yea sore the weather report and decided to save it for a night where their wouldn't be so many teenie boppers around (hsc time ftw!!)
https://www.sau.com.au/forums/topic/338543-creek-tonight/#findComment-5472194
lol, man you get some sorts there... There was a dude there with bike running purely on car batteries, an OLD overweight man with a standard NA VL, car full of kids in a verada, list goes on. It was too packed and sooo many shitters wasting time
https://www.sau.com.au/forums/topic/338543-creek-tonight/#findComment-5472633
What the hell, I thought WSID was meant to be serious, like everyone in helmets, rah rah rah.
*scratches head*
https://www.sau.com.au/forums/topic/338543-creek-tonight/#findComment-5472662
I was there and spoke to you GDZ14R. Nice 34 you have. I didnt get to speak with you after my 3rd run. I ran a 11.2 @ 130 mph. Very happy with my mph but just couldnt get the 60'ft where i wanted it. Shame the weather came in as my times were getting faster each run.
Who owns that black 32 gtr that was running ?
Tim.
https://www.sau.com.au/forums/topic/338543-creek-tonight/#findComment-5473871
Tim.
Hey Tim. I just put 2 n 2 together, you sold your old bottom-end to my mate Dave, who is the dude i was telling you bout stuck on 11's. I found the ad you posted and let him know after he cooked his old stocker.
Thanks mate, great job with the colour on yours too! 130 is really moving, only a matter of time before you crack the magic mark. Don't know the bloke with the black one, just managed a peak under the bonnet.
The weather put my night out of its misery.. Let me know when you have another crack, i'll come down with Dave.
Elz
https://www.sau.com.au/forums/topic/338543-creek-tonight/#findComment-5474127
  • 2 months later...
So did anyone go? I saw a few Skylines but no one I recognised.
Bit disappointed with times but it was epically hot! Managed to get an 11.9 once the sun went down and the temps dropped a bit. All good though, the white beast lives to fight another day :)
https://www.sau.com.au/forums/topic/338543-creek-tonight/#findComment-5593246
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
