  • Replies 43
Yeah, I admit it does look a bit like Megatron, but I reckon the official pics, when they come out, will do it justice.
In the end I think I could put up with the looks for Veyron-matching performance capabilities.
Hottest car on the face of the earth.
And when you have a car that weights under a tonne and can do 0-100 in 2.5 seconds, you're allowed to make it look anyway you want to because if anyone says anything about them, simply challenge them to a race. When they back the f**k down, laugh at them from the drivers seat of your ugly car and then drive off.
here's a bunch of 'teaser' shots previously released,
1. Bonnet:
2. Engine cover:
3. Dash through to cabin (seat and steering wheel in background):
4. Wheel:
5. Possibly the world's sexiest seat through to steering wheel:
6. Rear vent with spoiler base:
It is over the top. But so is Lamborghini in general.
You shouldn't buy a super car (esp a Lambo) if you want something subtle.
I thinks its awesome.
Astin Martin DBS.
The best super car in my opinion. No its not the fastest, but it is the epitome of style, class and power. It still looks badass but it does it in a classy way not by raping your eyes with over the top styling.
The DBS may not be the fastest around a track but I know that every supercar out performs my driving ability so really the fact that its not as fast is basically meaningless to me.
Merc and Gall are both still secksy though. This one just missed the mark.
Edited by person
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
