  • Replies 108
I'm gonna do some really early runs then chill till the eliminations
It'll be you & me, & damn near EVERYONE else following the same plan mate.
F@$&!#G weather :P It just had to pick the one day a yr that the Nats are on to hit mid 40's!
Yeah it sucks but what can you do?!
This arvo my car started doing something unusual - I had my exhaust fixed this morning cos I bent it a bit on a kerb (long story) and now it seems to get a real shudder around 4,500rpm in almost every gear .... either that or my flywheel is slipping (is that even possible?) .... either way I don't like it. Will see how it goes tomorrow. Other than that the power is excellent currently so I am fairly happy.
I just put 4 litres of tolulene in my tank with 20 litres of fuel .... that'll hopefully prevent any pinging in the hot weather :P
Looking at tonights BOM update there's a tiny chance things will cool down a tad later in the evening...... It does give a Min on Sat & Sun of low/mid 20's though.
Saturday : Very hot with freshening northeast to northwest winds, ahead of a
*moderate to fresh west to southwest wind change during the afternoon. Becoming
milder in the evening*. A possible thundery shower about the northern ranges with
the change.
Adelaide City Min 24 Max 43
Elizabeth Min 23 Max 43
Yep. Too many 180Bs, magnas & crappy chookcookers.
We should just have our own one next year - still meet with the big group,
but then go else where so we dont get stuck behind 16 y/olds in mummys magna.
SAPOL & Regency pressure has certainly pushed a number of the "nicer/serious" cars into hiding. I for one will not go near a major cruise these days! It really is sad :) What ever happened to police discretion? We can thank the idiots who act before they nail the throttle/do burnouts & so on for the extreme scrutiny. I'm not saying don't have a bit of fun on the road but think before you act!
Rant over.
Thanks John :)
Like I said in one of the other threads, I'm happy considering the heat, running with a boost leak (could feel the car down on power on the 12.8) & over 12mths since I'd last hit the strip. I feel a bit bummed at not getting the full potential out of the car, but there's always next time.
yeah i was stuck behind a couple geminis and a pulsar everywhere, that made the cruise even worse
also a few people put there foot down (a bit)as they were leaving the carpark, and the cop was taking down there rego's
Hey all Was unable to get to the Nationals it was just one thing after another and in the heat travelling from the sticks was to much. Was the cruise like last years ? I heard it was a rotor nationals. GTR's was there any at all ? and Munro what happened? So many questions
Lets make the dates for the Nationals in Autum, with a pre arranged weather of around 23c and small breez. Plenty of half naked women serving the drivers with drinks and food, Great music and some interstate door slamers and top fuelers to spice it up that little more.
Anyway it was just an idea.
  • 3 weeks later...
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
