Hey guys i have my heart set on getting those rims for my car. I am really not sure what offset i want yet so if anyone know anyone who is selling locally (Melbourne) so i can decide the offsets i am looking for. The size and width is those for sure.
https://www.sau.com.au/forums/topic/338590-wtb-volks-18-x-105/
Mate best thing you could do is head over to Import Monster (around the corner from Racepace). He has a wide variety of wheels in the size you are after.
Have you decided what model Volks you want?? TE37's, CE28N's, LMGT4's??
i am after the GTC's....love their looks and pretty sure they should be good on tracks...what do you think? not sure what offsets to go for but still reading stuff about them....
Plan is to go tommorrow afternoon down to their workshop and have a chat with them if they can organise me with the coilovers and the rims i am after....
GT-C's are more of a 'bling' wheel rather than a track wheel.
They are not as light as the rims I mentioned above.
But if bling is your thing then go for it, but if it's performance your after then stick to the wheels I metioned.
Cheers
AARRRGHHH!!!! hate this...lol....lot of people told me that too...but i asked chris and in his email this is what he wrote:
"The Volk GTC’s are a good rim and fine on the track because they are a forged 2-piece wheel. 10 or 10.5 doesn’t matter. 10.5 allows you to run a 285 tyre if you ever wanted and will still run a 265 so that is the better option."
To what i understood by reading, i am pretty sure he said they are fine. Thats only why i started persuing these rims. Back to square one. LOL
now have to do more reading to find out what i want...why cant things be easy....hehehe
OK...simple question..whats the best rack rim? what size, width and offset?...all i want is the best for my car...thought GTC were somewhere in that category in looks and performace...
GT-C's are not a fully forged rim so he's telling you porkies. And have quite a bit more unsprung weight compared to the monoblocks.
Best bet are either CE28N or TE37's. I think you should see Aaron from IM about what's best for you. Another top rim is Nismo LMGT4, also made by Rays.
OK!!! so the best rims in the market for track/street use are one of these. And they they are as good as one another? Its just i want to put the best in my car. Wouldnt want to settle to second best unless i am either desperate or i have no option.
I am going to see Aaron from IM tommorrow to talk further. So these three are the best?
All of the three wheels I mentioned in my first post are a forged monoblock design, meaning they are strong and very light. It all depends which one you like and availability. If you choose either of these rims you will not need to change them unless you damage them or get sick of the look.
Be prepared to pay though, being 10.5 wide they are rare and not as accessible as 9.5 inch wide equivalents...
:mad:
:mad:
HEHEHE!!! Dont you worry. I am not going cheap on my car. Only the best is going to be on the car. Found one TE37 in 18 by 10.5 with KU36 semi slicks included 265/35/18. only did 2000km on them. Asking for 3600...Is it a good deal? How much am i looking for them brand new?
Mate that is a bargain!
They are worth around $4.3k-$4.5k brand new depending on exchange rate, and that's not including tyres!!!
What colour are the ones you found?
20000kms on those tyres there will be very little tread left on them. So those tyres are worthless. For around 4 grand you can buy brand new set of te37s
There's 1 too many zeros your seeing there Eugene!
they are bronze in colour...not too bad since my car is silver...would have prefered black to give a bit colour contrast i guess...i mailed him...so awaiting reply...
i called places...no names...got quoted 3.8k for normal and 3.6k for super laps with +15 offsets...same size....they are brand new too...if the conditions of the tyres are good then it might be a bargain otherwise itll be wise just to get the new ones for that price....
just unsure about the value and how good the KU36 semi slicks are....need to read on that....
For $3.6k get the super lap version, that's cheap.
Is that stock here in Aus or do you have to place an order??
PM the place you're getting these prices from, I'm interested in some TE37's super laps.
Cheers
If you decide to not buy them, please pass the sellers details to me (via PM obviously!).
Missed few sets already...
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
