R32
RB20det approx 450hp flywheel power 335 at wheels approx
GT25R turbo 440 HP
Hybrid bar plate cooler
GTR injectors
300zx airflow meter
HKS pod
500HP fuel pump
R33 5spd box
Cross drilled GTR type front discs
After market sway bars
Bilstein height adjustable suspension
Custom $5000 paint orange I believe this was the first 1 done black fleck bonnet Rear guards flared
No rear wing
$3000 MP3 stereo system sub amp etc splits
nizmo 300klm speedo
500HP direct clutch kit
Trust front bar new just fitted
$3000 Ray engineering wheels new 17" tyres
probably more details if i keep looking
everything looks standard no wild modifications
NOTHING TO SPEND UNLESS YOU WANT CUSTOM INTERIOR
$24,000
MORE PIX
http://www.directimported.com.au/orange32/pix.htm
https://www.sau.com.au/forums/topic/33860-400hp-r32-fs/
i have dyno sheet before GTR injetors and 300zx afm was put on @ 300HP at the treads
my mate in harvey bay has same combo as mine 335Hp at wheels with gtr inj and afm
i will post it up
https://www.sau.com.au/forums/topic/33860-400hp-r32-fs/#findComment-680567
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
