Guy's dones anyone know if fitting a vented bonnet like the Top Secret or Jun style ones will be a problem with an RB30 conversion? Just had the thought as I know the bonnet it quite tight on the timing belt cover with the stock bonnet and these drop down in the middle where the main centre venting is? Help please! If some can reccommend a suitable bonnet to run with the RB30 if these are no good that would be great as I have some serious underbonnet temp issues wth the downpipe and top mount all in a very small enclosed space!
Cheers
Lee
https://www.sau.com.au/forums/topic/339078-r33-gtr-rb30-fitting-vented-bonnet/
Cheers
Lee
I think you'll find some can fit, the 33 rb30 from my experience has more clearance cause of the shape of the stock bonnet in comparison to a 32 (which we all know has a terrible time fitting the engine in and bonnet closing).
Best bet will be to go to a shop with the bonnet you want, do a trial fit on site.
Cheers
Lee
Hey mate,
I have a friend with an RB30 with a similar bonnet to Top Secret style (one vent at the front that dips down) and had to remove it due to it fouling out on the cam cover. An adequate solution would be to get the Nismo Z Tune style bonnet, it doesn't dip down near the front of the engine. Only problem is trying to find one. I bought mine about 5 years ago but the company that made them in QLD have discontinued them.
Hope that helps...
Thanks for the replies guy's Al, That is a possible solutoin I could either customise my stock one or maybe do a custom bonnet complete. Will see what comes up!
Sorry for the double post. Was not sure where this was best placed.
Thank you
Lee
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
