hey guys,
car has developed a tinny rattling sound at idle. it seems to go away with throttle, and then as the revs drop it rattles again.
i got under the car and held one end of a screwdriver to everything i could think of, and the other to my ear - and i suspect it's related to the exhaust. it could be something simple like a loose heat shield or a stone caught behind a shield......but i'm also worried it could be something more sinister - like little bits of ceramic exhaust wheel bouncing around in front of the mesh on the cat converter.......
stock neo turbo has been running 11-12psi off the EBC.......is there any other way i can diagnose other than dropping the exhuast in front of the cat and seeing what comes out? its my first experience with a ceramic wheeled turbo, so any insight would be good!
for example, if the exhaust wheel does sh1t the bed, does it do it all at once, or will the blades break/chip off slowly.....? because the car is still boosting reasonably strong, only paranoia is making me question it....
cheers! Mat
https://www.sau.com.au/forums/topic/339093-name-that-rattling-sound/
if the wheel hits the sides itll really break up, not just small chips...
might just be easier to undo the 2 bolts on the exhaust and see, get the car hot, and spray some WD on the bolts and let it cool down, then theyll prob be easy to undo.
just dont ruin the gasket lol.
11-12psi should be fine.
someone else might have some more insight/ideas
my understanding was that the heat of excessive boost is what kills the ceramic wheel - so you get hairline fractures forming on the exhaust wheel which eventually give way sending fragments flying off at 10000000rpm - i guess my question is - if that happens, will it automatically lunch the turbo - or is there a chance that only small pieces have come off and the turbo could still be functioning, just not at an optimal rate (slower spool). and that those small pieces could be what is causing the rattling, as they are stuck in the front pipe and blowing about in front of the mesh on the cat. could also explain why the sound goes away under throttle as they are getting blasted up against the mesh.
doesnt sound like i'm going to get a confident answer......looks like it'll be a case of getting under the car after work tonight. crap.
Edited by SMOKEYC34
weather or not it is the wheel, might be a smart idea to take your dump off and check the condition of the wheel.
to my understanding (correct me if im wrong) the wheel is only coated in ceramic, so if the coating comes off the wheel can spool still, but the wheel is just smaller??
is boost response still the same? Does it feel laggier all of a sudden?
If so, loose actuator will let the gate "flapper" bounce around and can cause that noise. Common issue/tell-tale sign with hi-flows that use factory actuator so its plausible it could occur with a factory turbo as well.
Failing that - drop the exhaust @ the CAT and see what might fall out! :(
IF bits had come off the turbine you'd know about it. They're balanced pretty precisely and wouldnt last long at all if chunks, even small ones, were missing.
Drop the cat and see if its stuff and/or maybe the dump and have a look-see.
Hate to drop this to ya dude, but I'm gonna call - big end bearings.
A damaged bearing would sound like you're describing, with how it slightly goes away when you stab the throttle and up the revs.
I doubt it'd be turbo related.
Thats true... Drop the oil out and see if there are any silver bits in it. If your keen run a magnet through it and see what comes out.
youd know if the exhaust wheel was gone . the car would be slow as fuc k and it would have dropped its guts when it you were boosting it somewhere.
my guess it its the rusty f**ked "heatshield" double skin what ever the f**k you call it that surrounds the front pipe before the cat . it rusts out and the insulation eventually f**ks off and you get rattles when your engine is idling at a certian frequency and the shit stops rattling above idle
what is your front pipe like?
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
