Guys,
I've had my line for a few months now, loving every minute of it.
But something has been baffling me since word go.
on the back shelf there is a small (maybe the size of a 1ltr ice cream tub but flatter
) box with a few leds and whirring fans, when i asked the previous owner what this was (just after i had bought it) he shugged and said "a dehumidifier" i quizzed further and i was told that it came stock with his import.
No problems there, but the thing that is baffling me is none of my mates lines have one, or didnt when they bought them. Have i ended up with the ultimate rice accessorie option (pointless and electronic) or would some one have fitted it after purchase?
Messiah
https://www.sau.com.au/forums/topic/33955-dehumidifier/
Messiah
My Series II has one also and is constantly on - can't seem to find an on/off switch. My Mazda 626 Coupe import had one also (way back in 1990) that some kids stole out of it thinking it was a sub or something.
They were called air purifiers from what I remember - was your car a smokers' car in Japan as they seem popular with smokers cars.
Don't seem to do much though apart from use up power and take up space.
Cheers, Al
https://www.sau.com.au/forums/topic/33955-dehumidifier/#findComment-681741
PVA,
Pretty sure yeah, it sits well clear of the rear window on the back parcel shelf. not rigged into anything mechanical in the space next to the battery, just power.
Sounds to me like it is a dehumidifier/air filter of some type, heh now the curiosity is why i have one but most dont. Makes me feel all special.
https://www.sau.com.au/forums/topic/33955-dehumidifier/#findComment-682128
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
