Guys,
I've had my line for a few months now, loving every minute of it.
But something has been baffling me since word go.
on the back shelf there is a small (maybe the size of a 1ltr ice cream tub but flatter
) box with a few leds and whirring fans, when i asked the previous owner what this was (just after i had bought it) he shugged and said "a dehumidifier" i quizzed further and i was told that it came stock with his import.
No problems there, but the thing that is baffling me is none of my mates lines have one, or didnt when they bought them. Have i ended up with the ultimate rice accessorie option (pointless and electronic) or would some one have fitted it after purchase?
Messiah
https://www.sau.com.au/forums/topic/33955-dehumidifier/
Messiah
My Series II has one also and is constantly on - can't seem to find an on/off switch. My Mazda 626 Coupe import had one also (way back in 1990) that some kids stole out of it thinking it was a sub or something.
They were called air purifiers from what I remember - was your car a smokers' car in Japan as they seem popular with smokers cars.
Don't seem to do much though apart from use up power and take up space.
Cheers, Al
https://www.sau.com.au/forums/topic/33955-dehumidifier/#findComment-681741
PVA,
Pretty sure yeah, it sits well clear of the rear window on the back parcel shelf. not rigged into anything mechanical in the space next to the battery, just power.
Sounds to me like it is a dehumidifier/air filter of some type, heh now the curiosity is why i have one but most dont. Makes me feel all special.
https://www.sau.com.au/forums/topic/33955-dehumidifier/#findComment-682128
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
