jesus mate. Going at it for sure. I would've turfed it and gotten another shell by now. More the credit to ya mate.
nope. started with this one and this is the one I intend to build. I have patience and plenty of it. cash - not so much but I make do :)
of the last 10 R32s I have done 8 of them have been sideswiped and ALL of them had bent sills. so while everyone thinks its easier to look for a better shell you really do not know WHAT you are buying until you get stuck into it like I have. even the guys that are buying non runners ex japan get the same thing.
I built a starlet a few years back and that was done in a similar fashion. new bits everywhere and some used ones.
pete,
and its going to stay that way too. the dash copped a spray of armour all before I wrapped it back up in plastic. the other plastics are STILL in the box you put them in and they are sitting in the next room behind me at home. carpets - those are folded up and put in a BIG box. hard boot items - boxes.
near new car once I'm done. I was talking to a mate of mine who does things out of osaka and he's finally worked out what I am doing. if I was doing it to sell - I would not have bothered. I'm building it to keep for a number of years.
quick check off on the original list at the beginning of the topic:
Things to replace/repair: (I'll provide part numbers as I do them.)
ALL rubbers
both door sills (inner/outer)
repair front frame rails - due to someone lifting the car wrong..
inner front plastic guards - both sides.
rear parcel tray (this will be rebuilt)
seat belts - all 4
ALL interior covered trim - inc side window trims
heater vents - dash.
radio panel
rear console
panel under steering wheel. - someone bolted a turbo timer to it and made a horrible mess..
shifter cover
rubber shift boot that isolates the body from the inside cabin
A/C controller - mine does not light up - works fine.
Carpet - if I can still buy it.
instrument cluster panel - GTR version with clock.
every missing screw inside.
plastic screws in the sill panels
Sill panels with skyline logo
Floor mats - OEM.
things to tidy up / paint/clean
entire car - factory color with new decals and emblems
engine bay - factory flat red
black stone coat underneath/inside rear wheels
engine in factory black colors
small parts.
every clamp on the car - new if I can still get them.
not to mention the new panels I have bought.
front differential is in with Elite Racing Developments ( www.erd.com.au ) being cleaned up/rebuilt
I will have a number of spares left over out of the engine purchase. a 4 spd 4wd auto will be one of them.
RB25 DET 4WD block - came form a 09/97 C34 Stagea. I am going to change the intake to a GREDDY forward facing item so it all marries up with the GTR nose. the 4sped auto that is on it now will not be there when it goes in. the 5 spd will.
top shot. needs a GOOD clean.
front shot. it came with engine mounts as well. perfect as all I will need to do is drop it into the engine bay and wire it up.
for now it gets put on the shelf and oiled/turned once a week. I'm no where near ready for it to be fitted to the car.
Looking good mate currently doing same engine swap into my R33 Gts4 with Stagea engine...but using 32Gtr gearbox
Let me know if you have any issues or questions with swap
all I am doing with the engine at this point is checking it over and storing it. I'm a long way off from installing the thing. that engine is 6 months early..
awesome rebuild detail. Was contemplating how far to go with mine, this sorta puts it in perspective. Any chance you could take a pic of the new sunroof you sourced? Mine has worn rubbers in it, but the whole thing still works perfect. If i take it out, was wondering how easy it would be to slap some aftermarket rubber seals around it to reseal it.
certainly can. the roof glass is out of a 92 (bought new.) . I have it in storage as I really DO NOT want to destroy a $1200 piece of glass. mine worked sort of until I stripped it and gave it a good clean. now its much better.
get a good look at your glass panel as well mine was rusted underneath and that was NOT visible from the top
as for pulling the roof assy out- its a full upper interior gut. so A,B,C trims off. roof lining out and s second person to help with the s'roof assy. the thing is a bitch to get out by yourself and balance. once you have it out flip it over and drop 4 bolts out of the glass. glass will come off. realigning it is fun as its a in/out job a few times to get it in the right spot.
whilst you have it out have a good look at the main roof panel. if you see anything remotely like mine - get it fixed. otherwise its a glass out roof off exercise.
one request I do have since you have a s'roof car - where do your drains exit the car? there are 4 of them and they come out in the corners somewhere but I cannot find where.
a BIG thanks to DUH19 for letting me take 'useless' photos of his car. (white GTR)
I was having issues with the rear inner fuel tank bracket location and the actual bracket shape (FAST listed two different ones.) but it turns out that the bracket IS the same as the one I have here and it simply slides to the left one hole. his car helped me work that out :)
about to do a compression test on the engine - hopefully 150PSI + across all 6.
I have one small patch of rust, but its in the inner channel. The part where once the glass retracts into the roof you can then see it. As for the drainage, I assumed (havent had a chance to strip it out to look) that it was similar to other cars where it would start at the top corners and exit via drain tubes inside each panel to the closest corner of the car, like the two rear ones would be connected to tubes that go down inside the c pillars to exit out the bottom of the boot somewhere...? I dont have FAST avail, or I would spend some time looking. I know that when I worked building panels for holdens it was a similar setup.
on subaru the hoses exit cleanly from the car. I cannot find where they exit on this one. never looked at a holden one. FAST doesnt tell you where they exit. I wished it did.
ok compression test done:
1 - 142
2 - 150
3 - 138
4 - 160
5 - 147
6 - 143
done with a full battery , throttle fully open , used a snap on digi gauge.
3&4 concern me.
do I have to right to be worried??
drop some oil in the spark plug holes and try again - were all the spark plugs out also?
yet to do that. I did the test as I got the engine - on a pallet with oil in it. figure its been sitting for 4-5 months easy. all plugs IN
do a leak down test, then start looking further
really didn't want to go there just yet.
I was hoping to simply clean the thing up and use it. doesn't look like that is the case with this one.
I'm going to the shop in an hour or so anyway so I'll grab a squirt bottle and fill the bores with a bit of oil and repeat the process. ideally 150 + is good I take it?
it basically 138 that you would not want correct !!!
it was the high variance of 4 that worried me. last time I saw that was on a chev V8 and I had a head gasket problem.
the understanding that I have of the L6 is that anything below 140 is rebuild time and I can see $15k going into this engine quite easily if I had to rebuild it from scratch.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
