  • 3 weeks later...
bought new inside door handles and the surrounds. also bough a newer steering wheel . looks to be series 2 32.
i will pop images up once i get a pc or server running again. ( on ipad now main server died and that is getting replaced.)
heated mirror control switch - new
grab handle - rear
passenger visor new - S2 version
heated mirrors - last ones I'm told
emissions label - under hood
visor - drivers - new S2 version
oil change label
SRS label - this one was a mistake I do not have SRS.
label - unknown. yet to see where it goes.
tire placard - jap label
love this thread.
Just wondering if you ended up getting the heated mirrors working? I did a search and couldn't find anything, I have a pair of heated mirrors, and the associated switch. Just wondering if it's pointless, ie the wiring harness needs to be altered?
drv side 24124-04U02
pas side 24125-04U02
the key differeence in these harnesses is the extra two pin blue plug that comes out with the mirror control plug.if you find one in a wreck note that plug. that will indicate it is a northern car with the cold weather package.
if you do find one it will also have a larger battery tray,battery hold down, and heavier battery cables into the car.
i have a couple of these style cars on file if you need an entry point into FAST.
bear in mind those harnesses will be a couple hundred each IF the are available. i have yet to check. thinking about it , I MAY have a spare set of these. i will have to look.
im now kicking myself for not getting the harnesses of the wreck.... I would be interested if you have some. thanks
yet to look. been busy building a shop. from memory though i have two sets.
also bought this 20 min ago...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=230811772305
bnr 32 resto book.
  • 3 weeks later...
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
