hey guys well haveing a bit of a problem in the past few days have noticed my thermo fan is staying on ?the car sounds like a truck and i noticed the running temp is alot lower than normal soo not really sure what i could be because i know the fan is mechanical and runs from the motor any ideas what maybe causing this?
your fan clutch could be farked ... you will notice your fuel economy worsen very soon. New ones are about $220-250 from memory (not Nissan but aftermarket, some joint in Melb iirc sells them) Definately change the thermstat if you haven't in a while ..theyre cheap
I wouldn't bother .. new one is $200 .. easy to remove. It's that big chunk of metal that sits just behind the radiator fan (that spins the fan) - just 4 studs holding it.
ahh k nice any do u mean replace the whole fan ? or?
You don't need to replace the "fan" unless it's broken. The fan is bolted on top of the "fan clutch" which itself sits on top of the water pump pulley ... you just need the "fan clutch".
It's that chunk of metal that your plastic radiator fan is bolted onto ie. http://www.google.com.au/images?hl=en&...330&bih=935
Here you go .. http://www.daviescraig.com.au/Fan_Clutches...65-details.aspx
but that's for R34 GTT .. probably same for R33 but if you want, give them a call and make sure.
EDIT: come to think of it .. I still have my old one which works perfectly, you can have it for $50 and if it doesn't fit I'll take it back. I only changed mine in an elimination process amongst many other things whilst trying to reduce my fuel usage. (turned it was just the coilpacks + 40psi tire pressure gave me a drop from 17l/100Kms to 13l)
ahh k sounds good lol gonna go source one now the car sounds like a truck lol not cool already looks bad enough not being painted at the same time with black side skirts and a grey spoiler lol
yeah was gonna say look for a second hand one or look at getting the fluid inside replaced
dont quote me on this but im pretty sure it was around 50 dollars to get the fluid replaced. Im not sure where to get it done but
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
