Hi Guys,
so i just bought a skyline v35 from trader who advised me that i can use the
Shell Unleaded E10 fuel type.
does anybody here recommend this? the fuel cap says 'premium unleaded only'
and the shell website says 'shell Unleaded E10 has a minimum 94 octane rating'
is this ok? i don't know much about this stuff but hopefully you guys can help!
cheers!
https://www.sau.com.au/forums/topic/339952-shell-unleaded-e10/
No I would certainly not use it. I would only use 98 octane fuels.
On the shell website it also says:
If your vehicle manufacturer recommends a minimum 95 octane then Shell V-Power may be a more suitable fuel.
If they dont recommend it for cars that recommend 95 octane, I certainly wouldnt use it on cars that recommend 98 octane fuel.
Also, my experience using the old 100 octane shell fuel which also contained 10% ethanol was it got considerably worse fuel economy until you had it tuned for it.
well i'm currently using 95 octane cos its premium unleaded? i guess i'll keep to it..
E10 has up to 10% ethanol in it.
Unless your fuel system is designed to cope with it, dont use it. It chews away at rubber and plastic within the fuel systems.
As above.. not a good idea.
so just to clarify 95 octane is (at a minimum) the right fuel for me? lol i think i'm willingly confusing myself..
Hmm I thought all those myths had been put to rest. How many people are running E85 (85% ethanol) on this and other forums without issues with factory fuel lines etc??
No I think 98 octane is at minimum the right fuel for you. I would never use any less. Japan has 100 octane fuel.
Thats a myth. I've run 20% Toluene, many other additives. Not a single problem.
As for the OP, Id find a service station with BP98, Shell 98, or Caltex 98. They may cost you a few dollars more, but I bet you go more kms too.
For how long?
I know personally of race cars who have left ethanol fuels in their rubber fuel bladders and fuel lines for a couple of weeks between events and have chewed through standard fiel lines.
This is just my personal experience.. other people may have different experiences.
Edited by GTS4WD
well are there any adverse effects from pumping 95 octane fuel? cos i've been using that for a while now...and is it ok to mix 95 and 98..?
For how long?
dude, it's a myth. my car ran on E85 for about 18months straight, also didn't get driven for weeks at a time as well. Car still in perfect health.
if you're talking say a 1985 car or something like that, perhaps, but really any of our cars will be fine.
I noticed this and I asked the local Shell about it. They told me their E10 is only rated at 94 octane minimum. United E10 which I normally run in the daily is the same price (if not slightly cheaper) and is minimum 95 octane.
How do you find the E10, do you get worse fuel consumption? or is it tuned for it?
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
