Hi Guys,
so i just bought a skyline v35 from trader who advised me that i can use the
Shell Unleaded E10 fuel type.
does anybody here recommend this? the fuel cap says 'premium unleaded only'
and the shell website says 'shell Unleaded E10 has a minimum 94 octane rating'
is this ok? i don't know much about this stuff but hopefully you guys can help!
cheers!
https://www.sau.com.au/forums/topic/339952-shell-unleaded-e10/
No I would certainly not use it. I would only use 98 octane fuels.
On the shell website it also says:
If your vehicle manufacturer recommends a minimum 95 octane then Shell V-Power may be a more suitable fuel.
If they dont recommend it for cars that recommend 95 octane, I certainly wouldnt use it on cars that recommend 98 octane fuel.
Also, my experience using the old 100 octane shell fuel which also contained 10% ethanol was it got considerably worse fuel economy until you had it tuned for it.
well i'm currently using 95 octane cos its premium unleaded? i guess i'll keep to it..
E10 has up to 10% ethanol in it.
Unless your fuel system is designed to cope with it, dont use it. It chews away at rubber and plastic within the fuel systems.
As above.. not a good idea.
so just to clarify 95 octane is (at a minimum) the right fuel for me? lol i think i'm willingly confusing myself..
Hmm I thought all those myths had been put to rest. How many people are running E85 (85% ethanol) on this and other forums without issues with factory fuel lines etc??
No I think 98 octane is at minimum the right fuel for you. I would never use any less. Japan has 100 octane fuel.
Thats a myth. I've run 20% Toluene, many other additives. Not a single problem.
As for the OP, Id find a service station with BP98, Shell 98, or Caltex 98. They may cost you a few dollars more, but I bet you go more kms too.
For how long?
I know personally of race cars who have left ethanol fuels in their rubber fuel bladders and fuel lines for a couple of weeks between events and have chewed through standard fiel lines.
This is just my personal experience.. other people may have different experiences.
Edited by GTS4WD
well are there any adverse effects from pumping 95 octane fuel? cos i've been using that for a while now...and is it ok to mix 95 and 98..?
For how long?
dude, it's a myth. my car ran on E85 for about 18months straight, also didn't get driven for weeks at a time as well. Car still in perfect health.
if you're talking say a 1985 car or something like that, perhaps, but really any of our cars will be fine.
I noticed this and I asked the local Shell about it. They told me their E10 is only rated at 94 octane minimum. United E10 which I normally run in the daily is the same price (if not slightly cheaper) and is minimum 95 octane.
How do you find the E10, do you get worse fuel consumption? or is it tuned for it?
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
