  • Replies 49
DVS32R, yeah that's correct due to the mixture burning later in the power cycle, hence less time to cool before leaving the cylinder.
Also Stao, yeah he was deliberately keeping power low up top to conserve the engine. I agreed with this choice. This tune is somewhat mild all over though for the same reason.
The only way to decrease the forces acting against the wastegate+actuator is to either let off the throttle, or somehow restrict the pressure acting against the actuator. This is where a boost controller comes in.
In my scenario, adding a boost controller only increases boost between 4,000-5,000rpm after that it drops to the same level. This means that even with the actuator receiving almost no boost signal (boost controller) the wastegate flow is still pushing the wastegate flapper open and overpowering the actuator spring.
My thinking at the moment is whats the point in having these large turbos and then restricting them to 280-290rwkw. We would be better off with more responsive turbos that still make 280-290rwkw peak.
The latest 3071 0.82 result from Hektik is excellent, full boost at 3600rpm and still makes 280rwkw.
Well I'll end up pushing the turbo into it's correct comfort zone when I get back from Europe later in the year....then when my engine goes pop, I'll be able to keep using it. For now, it's still perfectly good for what it's doing.
  • 1 year later...
Hi,
Did some search and decided to revive this thread. I am having boost creep. Its a hybrid R33 turbo with HT18 exhaust setup and bored out comp housing etc.
On the dyno it was creeping badly just off the w/g actuator, from say 8psi through to 18psi(very bad eh). The tuner used the Link G4 Boost controller to settle it around 16psi max creep.
I currently am using the stock actuator - 7psi. I realised that might be the issue? Trying to get a solid 16psi. On the dyno she made 275kw @ 17-18psi, but that was with the creep.
On the road its like this - 2nd gear.. I get 7psi instantly, but it starts to creep around 5k. All I want is a solid 16psi roughly from 3500-4000rpm. I have a feeling it may be the actuator thats the problem though.
I'm picking up an R32 actuator this sunday to see whether that helps(10psi). Any thoughts in my situation?
A stiffer actuator wont help the wastegate flow more which is what you need when boost spikes. Perhaps you can grind the hole bigger but then you will definitely need the larger actuator.
I can get that done no worries. Im assuming that at around 5k, the exh gases are causing the flapper to close due to the weak 7psi spring.
Its so frustrating on the road, it feels like driving a big laggy turbo, lol.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
