OOOOOeeee....
Cut a hole in the boot floor and mount the intake/filter in the boot. Then cut a vent behind the licence plate so it can breathe...
if you put a vent behind the number plate you will get exhaust fumes in the cabin area.
  • Replies 206
Yeah i've decided not to because i may have to drive on gravel roads and it'll suck dust into my boot. And that will destroy all my amps and sub. Haha.
I'm sure marty has thought of the best way to do it.
no updates yet other then i have found new bumpers for my car. Not that exciting for all you fulla's. Should hopefully, might possibly have the car back early this week. However i'm not holding my breath cause i've been told that at least 3 times now.
http://www.youtube.com/watch?v=xnFA93_U9hY
Any one who says it wont work obviously has no abillity to think outside the box, the huge lag myth has been been eliminated and the water and dirt on/in the turbo and filter is easily fixed.
Yeah, but that is a 5.7L V8, Not a 3L six pot,
GT45's arent laggy on LS1's.
I'm still dubious on the results but I hope it does work.
I'm personally looking at doing it on my 5ltr fairlane but even then I would probably only go a 3540 with a .8 or maybe a 1.0 exhaust housing.
It's not the optimal set up but if you pick the right size turbo it can be a nice little power booster, and with the way the vic cops are if you can mount it high enough and put a cover over it it will keep it stealth.
If you want to do that I would get the smallest turbo you can get away with, the NC fairlane makes 165kws at the flywheel if you only want a bit more than that (say 165kw at the treads then you would only need something like a 28RS, not a 650hp gt35R, bit over kill imo.
yeah. At the end of the day with the stuff i'm doing to the car it will be making more power even if i wasn't putting a turbo in. Seeing as the engine i had was on its way out. I'm hanging out to get it back though. Hopefully the final result is a good one. It'll give me something to build on and hopefully help people who decide to do something simular!
Exactly :ermm:
Also the housing on that turbo is rather small, doesn't look any bigger than a .82 at best.
Very small for such a large capacity motor, and certainly aid alleviate the massive piping addition
did you have a look at the car you mean? Got two brand new bumpers for it so she won't look so bunged up. What coilovers would you recommend? And yeah i'm gonna find some fat, light, inconspicuous looking rims. Any suggestions there either?
S13 coilovers fitt fairly easily I believe... Marty willl be the one to ask. I have HSD's under my pig.
As for rims... I'd get a set of 15" steelies widened as much as possible each end, then put plastic hub caps back on!!!
haha yeah. Plastic hub caps would make it look grandpa spec! I've got standard silvia rims on it i believe. And there only 15's and look fairly low key. I'll shop around and fins some thing that blends in.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
