They have to suspect something first though. I'm not even sure what powers the police have when it comes to defects and inspecting your car. ie: if a cop asks you to pop your bonnet and rev the shit out of your car, do you have to? (I'm in tasi)
I've been pulled over a few times and they've only ever done there supposibly "Random" breath test and licence check.
I like that pod idea, might look into it, the pipe is chrome, we painted over it to make it look more low profile, because personally a big chrome intake pipe just screams "mod" to me.
For the time being what i have will have to do.
  • Replies 206
I think you have more of a chance of being defected on suspicion
If they catch you doing a burnout they will just make something up to get you defected, they don't really need any evidence at all and when you go through the defect inspection they will find the turbo installation, guaranteed.
Just keep this in mind that if you get it defected you'll have to take it all out and return to stock, or buy another car and transplant it. I doubt engineering it to be legal would be cheap or easy.
Depending on who you get at rta in tassie (and how strict they are) you should just be able to dissconect the turbo add a muffler, a different intake pipe with a pod on it or go back to the air box set up, and you should be right, the 31 i mentioned earlier was actually owned by 3 of my mates, one of them got a defect for something and instead of removing all the turbo set up he just disconnected the wastegate and ran a pipe from the plenum with a pod on it and after a bit of haggling with the rwc guy he managed to get a rwc like that.
The benefit with this set up is that everything is in the back so if you do get defected you should only have to make things right in the engine bay, an epa is a different story, best be keeping the stock exhaust that came of just incase that happens.
btw do you know what pump he put in to send the oil back to the engine?
A good idea would be to make up a bash/cover plate to go under your set up, make it less visible and stop most of the water, dirt and general crud bouncing up into your oil lines.
a rwc is completely different to a defect, if it gets defected there is no way you'll get passed unless it is all returned to stock, ecu, injectors, fuel reg everything.
Well i can only go off what happens in vic, here you get a defect and depending on minor or major you need to get a rwc, you then take the car to vic roads and they check the defect items and your done, if you get an epa notice and have to do an epa test then everything has to be put back to factory, not for a defect tho.
4.11 will get you better take off and higher cruising rpm's, 3.7 will give you better top speed and lower cruising rpm's
that said you'll only be doing around 250-300rpm more at 100kph
yeah i want to keep it auto. already have a stall convertor. My next step is the r33 auto box and lsd. Then a full s13 suspension conversion along with break upgrade (something like r33gtr or gtst breaks, the four piston ones) and fatter tires with good tires. then after that more engine performance.
i did the same with my last 31. if its just street duties and occasional track days r33 gts 2pots and rotors are a good up grade + you have a much larger choice of wheels as the 4pots come out 40mm past the hub
best way to tell what ratio you have is to pull the back cover off the diff before you install it and see whats stamped on the crownwheel. i think 4.11s are 37:9
manual 31 skylines are 3.7 factory (except gts)
auto 31 skylines are 3.9 factory
and all 31 pintaras are 4.11 factory, also 25 spline centre and axles instead of the 28 spline the skylines got.
and only the silo's and gts's came with lsd's, shit ones at that
quoted for truth. had mine rebuilt with commie VY cones (apparently the same but with stronger locking) and it was noisy within 2 years
the pinion and crown wheel from the pinni can be swapped directly onto the skyline diff/center
another way is to turn the wheels for 1 rotation and count the turns of the tailshaft.
Don't do burnouts and i don't hoon so i don't see my self giving them an excuse to pull me over. I know they don't need an excuse and will pull you over for next to nothing but i haven't had any drama's yet.
And thanks for the info Van Von. And everyone else i think we should get back to my car. My mechanic suggested trying water/metho injection. What are peoples thoughts on this? I was thinking running a pwr water to air intercooler and then only running the water/metho when on full throttle, ie; only when i want to boot it and get a bit more power.
Any idea's on making this setup low key? Including the intercooler placement. And would using the window washer bottle as the metho resovoir be dangerous due to engine bay heat and the fact that 50/50 water metho is still flamable?
Cheers
Kurt
My mates had a front mount, he cut minimal amount of front bar for decent air flow and painted the cooler black, unless you were bending down in front of the car looking for a front mount you would never see it.
water meth can be good if you are limited by ignition and intake temps, but if you haven't maxed out the turbo yet then I wouldn't bother, you will probably find the limits of stock pistons and bottom end before you need water meth. Also whilst it works well if you run out mid boosting say good by motor.
I would consider E85 before you try water meth, E85 means more ignition and more boost and more power!
i've seen a few cars with the black intercoolers ( probably haven't noticed a lot of them), i have been considering it, but i was thinking a water air cooler would work better? Depending on where i mount it hopefully could eliminate heat soak after tha car is turned off.
I don't have stock pistons, the whole engine had been rebuilt and its been built to be tough. But like you say if its the last thing ya do when you want that bit more power i'll stick with the intercooler for now. And i don't think i would run out of the stuff. I'd be mega paranoid and would check/ refill it before every drive. haha.
Just realised how easy qouting is. Kinda proud of my self.
Cheers
Kurt
In that case I would push the turbo to its limits before looking at water meth, very easy to make 300kw before then, it is just extra complexity that can go wrong and if it does (pump breaks etc) it'll fry your motor right there and then.
same deal with water to air, good if done properly, but a good air to air is good enough most the time, if its done badly then w2a can be worse due to bad heat soak.
Edited by Rolls
a front mount would kind of negate the whole reason for going the sts setup wouldn’t it?
i thing the water to air cooler would be good if you can fit it under the car or, i dont know if it would work, replace the turbo to plenum pipe with a finned alloy pipe. kinda like a heat sink.
also then you could put the standard air box back in and run the intake through it for ultimate standard look
i wouldn’t worry about power upgrades till you've run the car in.
Not if done properly, would be pretty much invisible.
One of the problems with water to air is that it is great on low boost anf low flow situations (factory set up) but cant keep up with higher more constant boost, unless your willing to spend thousands on a custom water to air set up then an air to air would do a better job.
I wont be doing the power upgrades for sometime. Just trying to find out what is best for my setup that way if something comes up cheap i can grab it or what not.
I'm only really aiming for 300rwkw, so if i can get there without water/metho then i wont even go near it. I don't really like the thought of it too much.
Next time the car is up on the hoist i'll have a look under and around to see if i can fit anything anywhere.
I'm sure my mechanic will have some sort of idea. With a fmic, if i were to get a black one, have the intercoolers intake on the bottom passenger side so the pipe from the turbo can run along the bottom of the engine bay (hopefully out of site) and the have the outlet for the intercooler on the top passenger side, feeding into the factory air box hidden under the factory plastic snorkel thing, and then have it feed out of the bottom of the box where it would normally be and into the plenum.
Hope that makes sense? i'll try google something that looks simular or perhaps edit a picture.
Cheers
Kurt
nice project mate- i wouldnt worry about chrome plating pipes or putting a 'spare' pod on to make it look like thats the air intake, save your cash for a stronger 'box. It looks way sleeper as it is, 99% of cops wouldnt second guess your engine bay at all, looks boring as and well maintained.
ca 18 375cc injectors, all cleaned and flow tested.
As far as i know they should be suffiecent enough to handle the power i want to get out of the car.
Whats your car putting to the wheels?
you're probably close to maxing out those injectors already.
unfortunately the only way to use e85 over here atm is to buy it by the barrell, which is expensive. caltex arent interested in shipping it over here and even if they were its still illegal to sell in WA.
375cc injectors will max out somewhere between 190rwkw and 240rwkw depending on a few things.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
