http://www.carsguide.com.au/site/news-and-..._my_nissan_gt-r
Do you realise now Bobby, that after this article, you've got Nissan fans all around Oz scurrying to their grey import dealerships to check out if the staff don't realise what they've got?????
:P
Many thanks again Esther for coming all the way up to NSW...
And many thanks for your praise in the VIC thread!
:O
No worries at all Terry, it was so worth it!!! :D
Hey folks,
I finished the draft edit of the Video last night. There are a couple of scenes where one of my video filters put a watermark that I'll be removing.
If anyone wants a copy PM me. I'll just ask for a $5 donation for SAU to cover production and mailing costs.
I can author either a movie DVD or send a Data DVD with the hires Video File. Let me know which you prefer.
Magnificent Memento Disc received to-day from Matty.
Many Thanks Matt (and Kory) for your professionalism.
It's a Souvenir to always remember. :ermm:
No problems Terry, welcome :)
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
