Hey guys n gals
Well as most of you may know, I'm 16 - And i haven't got my L's yet due to lazyness. However i'm going to go get them within the next couple of weeks. My parent's cars are both Auto, so chances are i'm going to have to drive Auto until i get my car. Before i get my car i want to know a bit more about how to drive manual. I know the basics - Changing up and down, however i don't know much else, such as what to do when you're on a hill and stuff like that. Is there any way for someone to tell me the basics?? I know its best you learn out on the road in a car but i'd like to know a bit more and some tips'n'tricks about driving manual before i go and try it for myself
Cheers,
Ryan
https://www.sau.com.au/forums/topic/3404-driving-manual/
Don't stall the car!
(that looks really bad on a driving test :uh-huh: )
hehe
for a hill start, just start to release the clutch like you normally would but with one hand on the hand brake. As you feel the clutch engage, release the handbrake slowly and take off, so you get no roll-back.
ummm what else (it was a long time ago when i took my test LOL)
keep your hands on the 10 to 2 position on the steering wheel, and when you change gears always return them to this position...don't leave one hand sitting on the gear knob.
when you're coming to a stop at lights, always change down all the gears properly. Don't leave it in third and coast to a stop.
Make sure you take your foot all the way off the clutch after changing gears so you're not riding it at all.
That's all i can think of for now, they're all things they'll be watching for when you take your test (in regards to a manual car anyway) there's all the other general stuff as well regardless of whether it's auto or manual, like checking your mirrors, indicating etcetc...
https://www.sau.com.au/forums/topic/3404-driving-manual/#findComment-57372
Wear a really short skirt when you take the driving test.
It's not really that hard........
Actually, I had a shocker a couple of weeks ago. I was moving a 4 door gts-t & I couldn't drive it for sh*t, I was bunnyhopping & stalling all over the place.......Very embarrasing.
https://www.sau.com.au/forums/topic/3404-driving-manual/#findComment-57382
Guest nismogtsx
LOL.....
The short skirt is so true. I was at the Transport Dept
the other day paying for my boat lic. and this 16 year old
or 17 year old chick walked out with her testing guy and
was wearing a shirt so short you could see the bottom
of her bum......
Se wasent bad either... I bet she passed.
Then again maby he was gay???
https://www.sau.com.au/forums/topic/3404-driving-manual/#findComment-57682
or even rent a car from avis... i think its around $50 a day, of course in manual:D
u need a credit card, or $1000 cash deposit... and get ur mom to do all this for u (its cheaper that way i think... rather than 16year old boy wanting to rent a car ... keke)
and yeah, now for the fun bit, get one of ur mate who can drive a manual and get them to teach u.... and when taking rest, get them to teach u handbrake turns, hill toe, how clutch smells when burnt... and all those things that u would never do in ur own car :)
u have a car for whole 24 hour before returning it to avis, for $50 and petrol...
thats how my friend learnt manual..
https://www.sau.com.au/forums/topic/3404-driving-manual/#findComment-58768
lol@nissaner, a mate i know actually hired a car for a track day at Wakefield, from the on board footage i'm very surprised it didn't flip.
Jon: i've still got HPI sitten in my back seat for ya. If your cruisin this weekend give us a call, RAC33R said they might be gettin together saturday.
https://www.sau.com.au/forums/topic/3404-driving-manual/#findComment-60099
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
