I have entered but guessing I am even further down the waiting list :P Will be good to get some real kms on the car....anybody been to one of these days in a "noisy" car ? How are they with black noise flags?
Briefing notes from MSCA organising this weekend at PI say (see below) Doesn't mention anything about a dB requirement or black flagging etc. Obviously the absence of such specific information doesn't mean you're in the clear, but at least it's not in black and white. Seems at least noise is a sensitive issue and certainly before 9.00. Hope that helps.
So Phillip Island . DO NOT FORGET ABOUT NOISE RESTRICTIONS. No Noise at all before 9am. This is a restriction on all track users and only the V8's and Moto GP people are exempt. The Competitors have to push cars at RAce meetings,and yes, the scrutiny bay is uphill. Obviously cars that are driven to the track may drive , but no revving of engines will be allowed. Trailer cars may be started to unload but must keep revs to an absolute minimum . Any blatant abuse may result in the driver being sent home
Come one BB and Snowie if I can do it with my thing surely you two can get your things up there :P
I have entered but guessing I am even further down the waiting list Will be good to get some real kms on the car....anybody been to one of these days in a "noisy" car ? How are they with black noise flags?
To the best of my knowledge the only full noise days are PIARC, V8's and bikes any other track day has the usual restrictions including this one. 90db measured at the side of the track (I think 3m away from the track itself but I could be wrong).
Come one BB and Snowie if I can do it with my thing surely you two can get your things up there :woot:
Sounds like the 050's are the tyre to have - they appear to be putting out consistently quicker times. I'll be happy to have a reliable day to finish the year off. :P
Well, I will put their noise restrictions under the torch and see what happens
MSCA are generally vintage cars so may do 90dba+ days at PI.
I'm doing MSCA at Sandown on the 5th. One last blast there for the year.
No question they are a great tyre able to put out quick times....however on a heavy car like the R (well my car in particular!) they tend to only give 2 or so hot laps before getting too hot and sliding around. I've found the RE55 is far more consistant over a 5 lap sprint than the A050 at tracks like Sandown and PI.
    • So I actually had the cover off my car today, here is a (bad) pic of the setup. I have an oil cooler thermostat block, the temp sender is straight in there. The pressure sender has a short AN line to a T piece which is mounted (hopefully cable tied counts as mounted....) on the chassis. BTW every fitting you could ever imagine exists....just depends what they cost and how many you need. Raceworx AN adapters are here: https://raceworks.com.au/fittings/adapters/, I think you said you need BSPT to AN (https://raceworks.com.au/fittings/adapters/bsp/tapered/an-to-bspt-adapters/) and AN to NPT (https://raceworks.com.au/fittings/adapters/npt/) BTW, braided line is super simple to make. It looks intimidating, is not.
    • Perfect day for a pie, really needs a soft top in this weather though
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
