1) Will a Bosch 040 intank fuel pump flow enough fuel (with 600cc injectors) to run e85 in an R34 GTT that makes would make about 270-280rwkw on 98 fuel?
2) Would you trust this water pump on the above car - http://cgi.ebay.com.au/Skyline-R33-R34-GTR...=item3a5e15906a - or should I get a genuine nissan item. Does the R34 GTT really use exactly the same waterpump that the R33 GTST does? I seem to remember there was one less or one more bolt or something.
3) Do thermostats wear out at all? Should I just replace it while I have the engine out. The engine has done just over 100,000 kms.
Thanks!! :ninja:
https://www.sau.com.au/forums/topic/340436-3-really-quick-questions/
1. yes
2. no, std is fine, oem is bulletproof
3. no
Thanks for the answers, much appreciated!
I will get the OEM water pump then. Only trouble it is double the price at about $260!
One more question hopefully someone wouldn't mind anwering.....
I currently have the head off on my RB25DET Neo. Do I really need a new set of head bolts when putting it back together? And if so should i definately replace them with ARP studs and bolts instead (going for about 270-280rwkw). Will using the studs mean I dont need to replace them next time if I need to pull the head off again? And does using studs mean I may have clearance issues if I needed to pull the head off again in the future when the rest of the engine is still in the car?
The engine sits quite close to the firewall, it looks like if you were to pull the head upwards to clear the studs it might hit something making it difficult to get out.
That was kinda more than one question... :P
3. Is yes.
They do wear out. Plain and simple I wont even bother explaining it. One day the thing will stop working, no set time frame.
As stated, $30 bucks just change the damn thing.
3. Is yes.
OK, will do, thanks :P
nissan service manual doesnt say to change the head bolts after every use. its usually recommended when building a motor but its not essential. i re used the stockers when building my 30det, head hasnt lifted off yet.....
3. no
Judging by the completely perished condition of the seal on the thermostat I pulled out of my car at the 100,000km service a few weeks ago - I'd have to completely disagree with that.
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
