  • Replies 55
if i get plenty of notice, and i'm not busy then (when you announce date)... then i might just have to put money aside for this one.... :) dunno though... depends on how tight budget is... might have to just come and watch... only time will tell... :spank:
you have lots of notice
look like early april
questions
i use my standard road car s13 silvia
my brother and i used it the last drift day i held the car did over 140 km and we used two sets of tyre
the first set shredded becasue i did 4 full laps in a row
if you let your tyres cool abit they last forever
pete
Yeah Baby lets see if i can destroy this perfectly good HR. This time im disconnecting the HICAS!. I`ll be pickin it up tomoz and hopefully ill have the gearboxes changed on sunday. then we`ll see what the crappy NICS motor can do before i destroy it YEAH BABY. oh yeah back to the thread count me in Fatz just don`t expect me to go fast on the doosie.
depending on date....I'll drop by and teach you a few things :)
:bahaha: Nice one Duncan... I thought that fatz was the only one to have your car intentially slideways! :mad:
IN IN IN :wavey: IN IN IN :wavey: IN IN IN :wavey: IN IN IN :wavey: IN IN IN!!!
2.  How much tyre wear do you usually get on a day like this?
It seemed to depend on the car.
I'm running stock power and wasn't constantly linking corners, so one set lasted the whole day, as they did for lots of other people.
However, guys who had lots of power and smoked it a lot (like the Autostyle Skylines) and those who were linking corners and doing sway drifts down the straight (like fatz) needed more than one set.
I've got a reasonable amount of power (nothing huge, but enough) and I only managed to send my outside tyre bald.  I'm still a newbie though, I'll be giving the next set a MUCH harder time :cheers:
crikey i'll be in my stocker silhouette
shithouse in lowdown power. but i'll be giving it a go.
should be fun boys
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
