i've never owned a turbo before so i was hoping someone could help me out a little..
im running a completely stock 34 gt-t and sometimes on ignition the boost gauge won't move, not even a slight fluctuation, today i was driving and the gauge had been sitting on nothing, then doing 60 it suddenly jumped to about midway up the gauge, stayed at that pressure for 10 seconds, then dropped disturbingly quickly back to 0, im not sure whether it's because i've only started looking at the boost gauge while driving that i've noticed it goes for ages without moving from 0, i can hear the whirring/spooling? sound but without gunning it, cant tell wether it's active. i had a major service (smooth garage) and immbolizer installed friday if thats relevant at all..
basically i'm dumb, is there something wrong? or is that normal behaviour? only just bought it, i'll be pissed if it's already playing up. :whistling: is my best bet getting a compression test?
cheers guys
https://www.sau.com.au/forums/topic/340898-faulty-turbo/
cheers guys
Sounds like your boost sender has a dry solder joint or its your guage. dosent sound like the turbo its just the electronics
https://www.sau.com.au/forums/topic/340898-faulty-turbo/#findComment-5502907
+1
Don't panic just yet. Get the boost gauge checked out. :whistling:
https://www.sau.com.au/forums/topic/340898-faulty-turbo/#findComment-5502912
34's quite often have dodgey sender units dont they?
If that is indeed what it is, dont panic at all, its a 30 second fix.
BTW, to the best of my knowledge, a turbo wont intermittently boost, it either will, or wont, not both.
https://www.sau.com.au/forums/topic/340898-faulty-turbo/#findComment-5502927
thats what i thought, is there anyway i can fix this myself? i think supercheap has 60mm gauges i could grab but installing it would no doubt be a nightmare >__< gauges are half the fun of owning a turbo imo
https://www.sau.com.au/forums/topic/340898-faulty-turbo/#findComment-5502937
I recently re-soldered the dry joints on normsta's boost sender that was doing the same thing.
If you're comfortable with a soldering iron, it's about a 15 minute job to take it out, hit it with the soldering iron and put it back in.
The other thing that normally breaks about the same time is the vacuum hose back to the plenum. It'll often crack when you try and pull the sender out to replace anyway. I'd suggest try changing the vacuum hosing and then if that doesn't fix it, look at hitting up those dry solder joints. It's the three main ones coming back to the plug. There's a thread on it somewhere if you hit up search.
https://www.sau.com.au/forums/topic/340898-faulty-turbo/#findComment-5502942
i'm in croydon, i found a tutorial about resoldering the three joins on the chip above the front right tire, scared about messing with it, it's under a three month warranty, doubtful but would that cover this?
https://www.sau.com.au/forums/topic/340898-faulty-turbo/#findComment-5503032
yeah take it to Jenna save some money and she can show you some things about your car :(
uhhh .. what's a car .. I'm just a girl :whistling:
You could ask them - couldn't hurt to give it a shot. :blush:
It's pretty easy to do if you have access to a 10mm spanner to unbolt it, and a soldering iron to re-flow the three joins though :P
The hardest part is undoing the damn clips around the edge of the sensor, I always struggle with that bit.
https://www.sau.com.au/forums/topic/340898-faulty-turbo/#findComment-5503038
to update, i've checked all the cables and the vaccum line as best i can, all in good working order by the look of things gonna try and pry open the boost control chip case and go from there.
https://www.sau.com.au/forums/topic/340898-faulty-turbo/#findComment-5503138
managed to get a hold of a soldering iron but i can't seem to get the boost unit case open, i don't want to crack or break it but can't seem to find a way of getting it off
edit:
i mean the larger case just above the right wheel, not the part sitting above the engine
Edited by trappedunderice
https://www.sau.com.au/forums/topic/340898-faulty-turbo/#findComment-5503254
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
