I know all of us are sick of the RTA but today I've just had enough of them.
Yesterday I called their "helpline" and was forced to wait for 10 minutes before I got to speak to a real person. I literally said half a sentence before the bitch promptly told me I was calling the wrong thing and put me to another press a button option bullsh*t. Wait another frikkin 10 minutes and the same thing, only this time the kind lady put me in the right queue!
When I got through, I got the info I needed and was mildly happy. I took me 30 minutes on the phone to find out that I need to present ID and my cars rego papers to have their number plates swapped...oh and the $50 revenue, oh I mean processing fee.
Today. I went to the RTA at Macquarie Centre during my lunch break. I wait about 25 minutes to be served (3 people attending and about 3 people standing around doing nothing). When I get there and present my rego papers the frikkin bitch told me that I need to present my frikkin plates! what. the. fruck?! She then pulled out the "we're sorry" bullsh*t... Seriously I'm so fed up with the RTA. Firstly they charge us a mortgage to get our cars registered and they can't even provide adequate amounts of staff and service...
NOT HAPPY JAN.
https://www.sau.com.au/forums/topic/34104-a-big-f-you-rta/
Ignorant ex-pat inquiry #477:
Whats "Not Happy Jan"? :)
Ha ha ha ha ha ha ha ha - It's a commercial over here Rezz. This woman get's pissed off and says " Not Happy Jan " casue Jan is the one she is not happy with. Anyway, you need to see the commercial to understand - It's funny as....
Hence everyone now says "Not happy Jan" -
https://www.sau.com.au/forums/topic/34104-a-big-f-you-rta/#findComment-683849
Never go to the RTA during your lunch break unless u r going to clear a canary :)
Its always packed as mofo
true but I took my lunch at 2-3PM cos most people are back at work by 2...
Useless bunch they are...seriously with the amount of money they make surely Sydney should have some of the best roads in Australia...
https://www.sau.com.au/forums/topic/34104-a-big-f-you-rta/#findComment-683852
CK: Are you getting the plates under the new $400/yr BS?
Maybe the $100 coloured plates?
The RTA is a pain in the bumhole.
I call in work time (may as well).
Tell me colleagues I may be gone for a while and pack a lunch.
You have to be prepared.
The more you know their procedure, the more you can present the right documents when they need it.
They are process workers like any other bureacracy and you're just a number (literally) so take it easy on the counter staff.
I would imagine it's the same in every country because you keep hearing about the DMV ("Patty and Selma") and the MoT on TV shows.
One day though... when the revolution happens, they'll be first up against the wall.
T.
https://www.sau.com.au/forums/topic/34104-a-big-f-you-rta/#findComment-684017
Personally I feel sorry for the RTA counter workers.. they have to deal with every f*cking lunatic on the road -- half of whom are brain dead -- so take pitty and be as nice as you can (stomach), because its often far more productive than being agro.
LW.
https://www.sau.com.au/forums/topic/34104-a-big-f-you-rta/#findComment-684020
nah 400 a year is the leet plates, rego is about 800 including ctp insurance.
I had to go on Saturday to renew my rego last dec, waited for 1.5 bloody hours :)
But, for a bit of fun, next time you are there, get a copy of your driving record, it costs about $20 and mine looks a bit like a novel :spank:
https://www.sau.com.au/forums/topic/34104-a-big-f-you-rta/#findComment-684258
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
