Hi Guys,
Has anybody else had problems with their short shifters?
Mine seems to have broken... I have never shifted hard with it at all and the top part (where the gear knob screws on) has come away from the bottom part (which drops down into the gearbox) - it still works, theres a rod from the bottom half which slides up the inside of the top half which allows it to still function, but i am not happy about it breaking.. its only about 6 months old.
It wasn't in a box tho when i got it, so perhaps its not a Genuine C's?
Christian
https://www.sau.com.au/forums/topic/34106-cs-short-shifter-problem/
had mine well over 6 months, and all is good touch wood. Mine came in a box new.
Does it have any C's markings on it at all? mine came in a plastic bag with just a C's Guarentee card and the bits needed to fit it.
Christian
looks original enough for me, bought one before but didn't put it on decided to sell it again. it looks like it uses some glue between the two parts. can't u just glue them back with some kind of glue that will work with metal parts?
Agree with RS73....looks to have been bonded in place and glue's only partly taken. Shouldn't happen on a new part. Simple job to repair yourself, just remove as much of the old glue as possible from both parts (hard to do in a hole, of course), then roughen up the surfaces with emery/sandpaper before re-glueing. I'd try something like 24hour araldite (NOT the 5min stuff, which is crap).
Of course, if you think you've got a chance at a guarantee/warranty claim, do that first....
C's is now out of business, so no Warranty claim. :)
The fiancee is out shopping tonight, I have her picking me up some silicon based adhesive as I have drag combat on saturday (thank god i decided not to run!!)
Thanks guys,
Christian
you own and drive a gtr so use it in the right enviroment.
whoa, i wish you were in Sydney to see the 'PranK GTR Driving Style'. :P:)
the general rules are; because you love your car, spend as long as possible in it, so no speeding, in fact - go UNDER the speed limit. And also because you love your car and own a GTR, dont even THINK of dong anything that would jeopardise your license status and/or premium raise. :rofl:
You have nothing to worry about with me.
Sorry to hear about your friend.
Christian
btw i've got a mines short shift on mine and it jammed halfway through the gate into third at sandown last sat. Maybe nissan OE is the go?
Well, since mine broke today, I called a few mates at some workshops and they were almost all of the opinion that the nissan stocker is much better for the g/box and to shift with (I have my stocker in the garage).
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
