r34 turbo wont 'bolt straight up'. only the dump pipe is different
series 1 and 2 r33 turbos will bolt straight up, and the difference between the 2 is minimal. yes the compressor wheels are different but they both got ceramic exhaust wheels and thats the time-bomb which starts ticking after 12psi
https://www.sau.com.au/forums/topic/341119-rb25-turbo/#findComment-5508662
