Hey all
Have decided that i am going to strip my car and sell off the parts so get in quick.
Car is currently still together but will start taking her apart over the weekend
below is what i have
ITEM : GENUINE HKS 25/30 ( LESS THEN 3000KM ON TURBO, NO PLAY AT ALL )
ITEM : GENUINE HKS SERIES 2 DUMP ( LARGER WASTEGATE PIPE )
ITEM : XSPEED JAPAN STAINLESS LOW MOUNT EXHAUST MANIFOLD
ALL FITTINGS AND LINES
CONDITION : near new
THIS KIT MADE 270RWKW AND 840NM OF TORQUE ON MY BUILT RB24
AWESOME SETUP , INSTANT RESPONSE
PRICE - $2000.00 complete, $1500 for turbo- turbo lines and acuator, $300 hks series 2 dump, $500 for xspeed manifold
ITEM : Siemens 600cc injectors with HKS fuel rail
CONDITION : Near new , cost $1500 less then 500KM ago
PRICE : $ 800 complete
ITEM : Sard fuel regulator ( custom top secret sard special )
CONDITION : NEAR NEW
PRICE : $200
ITEM : Cusco coil overs for r32 ( will fit others as well )
CONDITION : great, no leaks
PRICE : $1000
ITEM : R33 GTR rims and tyres
CONDITION : OK, have a couple scrapes and rash marks
PRICE : $750
ITEM : Custom SPEED LAB front mount 600X330X125 ( BIG )
CONDITION : NEAR NEW, PIPING NOT INCLUDED
PRICE : $600
ITEM : Custom GTR plenum & throttle bodies for RB20 head
MUST HAVE FOR ANY ONE WITH A RB20!! ALOT OF HARD WORK WENT INTO THE MAKING OF THIS. SOUNDS AWESOME.
CONDITION : GREAT
PRICE : $1200
ITEM : Autronic SM-4 with custom RB loom, sensors and LED's
CONDITION : Next to brand new
CAN BE RE PROGRAMMED TO SUIT ANY APPLICATION, WAS TUNED AND AND MADE FOR ALL THE ABOVE ITEMS.
PRICE : $1900 ( sm4 alone is $2300 new )
ITEM : Kaaz 2 way diff with GTR cover plate for better cooling and more oil
CONDITION : GREAT
PRICE : $800
ITEM : R33 GTR V-SPEC front seats
CONDITION : Great, no marks or tears!
PRICE : $650.00 pair
ITEM : R32 GTST front seats
CONDITION : Good for age
PRICE : $100 pair
ITEM : HKS twin plate for RB20 ( may fit other )
PRICE : $1250
ITEM : N1 R32 head lights ( stand out from the crowed )
CONDITION : Great
PRICE : $400 pair
ITEM : R32 Rear PODS in white
CONDITION : OK
PRICE : $120 pair
ITEM : R32 GTR brakes with sloted rotors and top secret pads
CONDITION : great
PRICE : $600 front and rear
ITEM : Front / reat r32 strut bars
CONDITION : Good
PRICE : $150 PAIR
ITEM : CUSCO r32 brake master stopper
PRICE : $100
ITEM : BUILT RB24
ENGINE HAS JUST BEEN RUN IN WITH A HKS 25/30 AND IS A ANIMAL!! MADE 270RWKW & 840NM TORQUE !!!! DYNO PRINTOUT PROVEN
BOTTOM END IS BRAND NEW
SPEEDLAB CUSTOM RB24 ( CUSTOM MACHINED R34 GTR CRANK )
GRUB SCREWED CRANK
LINISHED CRANK
EAGLE RODS
TOMEI PISTONS
ARP RACE SERIES STUDS
TOMEI RINGS
PISTONS HAVE BEEN TEFLON COATED
FRESH LINE BORE AND HONE
ACL RACE SERIES MAIN AND ROD BEARINGS
CUSTOM SUMP BAFFLES WITH TRAP DOORS
CUSTOM 9L SUMP
N1 OIL PUMP
N1 WATER PUMP
CUSTOM HKS 1.2MM HEAD GASKET
THIS BOTTOM END HAS BEEN MADE TO STAND BIG HP AND BIG RPM. ONLY TOP QUALITY PARTS FROM JAPAN, USED AND THE BEST MACHINING HAS BEEN DONE.
THIS BOTTOM END HAS COST ME BIG $$$
ENGINE ( HEAD )
FULL RACE PORTING
JUN 272 – 10.8mm LIFT ( BIG ) INLET AND EXHAUST CAMS
JJR ADJUSTABLE CAM GEARS
TOMEI SPRINGS
TOMEI BUCKETS
GREDDY TIMING BELT
CUSTOM OIL DRAIN MACHINED FROM THE BACK OF THE HEAD TO SUMP.
CUSTOM PAINTED ENGINE COVERS
THIS HEAD HAS HAD OVER $7K SPENT ON IT IN MACHINING AND PARTS FROM JAPAN.
THIS WOULD MAKE A GREAT STREET ENGINE OR TRACK ENGINE.
PRICE : $7500
ITEM : R32 four door shell
SILVER, BODY IS A LITTLE RUFF BUT STILL PRITTY GOOD CONSIDERING ITS OVER 20 YEARS OLD
1989 MODEL
HYDROLIC HAND BRAKE
ARC FRONT CASTER ARMS
CUSCO UPPER FRONT ARMS
CUSCO REAR UPPER ARMS
CEFIRO ENGINE X MEMBER ( ENGINE SITS LOWER THE STANDARD X MEMBER )
90% OF INTERIOR STILL THERE
99% OF ALL PANELS
BOSCH 044 AND CUSTOM SWIRL POT
D1 DEEP DISH STEERING WHEEL
HEAPS OF OTHER BITS AND PEICES
MINUS THE BELOW
NO ENGINE OR ENGINE RELATED PARTS
NO GEAR BOX
NO DIFF
NO ECU OR WIRING
NO SUSPENSION
NO WHEELS
NO HEAD LIGHTS
COUPLE OTHER SMALL BITS MISSING
CONDITION : OK for age and comes with alot of parts and listed parts not with car
$2200.00 INCLUDING REGO!
OR TAKE THE COMPLETE CAR AND ALL PARTS $16K !!!
LOCATION : ALL ITEMS ARE IN ADELAIDE, POSTAGE AT BUYERS EXPENSE
CONTACT : PM ME
PICTURES : CAN MMS PEOPLE PICS
  • Replies 52
Rims back up for sale due to sale falling thru
gixxer07, PM me your number and ill mms you pics, HKS 25/30 on a sr20 would be pritty good , nice and responsive with a decent power band
hey mate, my mate might be interested in the 33 gtr rims...still got that for sale? if do where are you located and could you please pm me some pics of it? thnx...
Are these high or low impedance?
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
