I do my own car washes, but I think I'm due for a full cut and polish.
I don't trust myself to do it in case I screw up the paint work so I want to get it done professionally.
Never been to a detailing place before, but I have found a few places around here in Wollongong.
Not sure which one to goto though, so was wondering where people have gone to before and what were the results like?
Also, would you go back there again?
How much did they charge you and what did you get done exactly?
When I imported my skyline I got it detailed at Evershine Car Detailing in Dapto
20 Hamilton St
2530 Dapto NSW
Phone: (02) 4261 5424
They did a full cut and polish and also some paint touch ups etc..... I can't remember the exact work & figure, because it was back in 2003 I think, Fark.....7yrs ago I bought that car!
Maybe around $3-400 off the top of my head. I haven't been back since, but only because I've had no need. But I would go back there if I did need too.
Next door to W.A.S, kons brother is the best, go past and see what he has in there and that'll make your mind up
Next to Wollongong automotive services you say?
Are they in Auburn street? Do you have the exact address? I cant seem to find them..
I've just been to W.A.S today after work and they said I can take my car in on Monday morning :ermm: It was just near HangDog as you said Owen :)
They said it will cost between 200-$500 depending on how far I want to go with it, step by step. Will take a couple days apparently. Buffing, get rid of swirls, paint chips, blemishes and any other marks.
He said whoever buffed it last didn't do a great job as there are some buff marks in some places and its had some resprays in some areas in its time. Also looks like the boot has had a bit of over spray aswell.
Edited by Owens
Can you get some before and after photos using a DSLR?
Sure thing :ermm:
Buffing won't get rid of chips because there's no paint there to polish. If you can feel the chip or scratch with your fingernails, it's pretty deep.
yeah, he'll be touching it up with paint.
Edited by Owens
Might be too late for that. I just said I heard about W.A.S on the skyline Australia forum lol. They seemed to know what I was talking about.
Will let you know the results tomorrow arvo!
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
