geez you guys must be really strong? on a serious note...is this the rears only steve or the front you wanna swap unsidedown? if its the rears i can help you as itll be a 10 min job.
Haha, yeah. Get to use the muscle.
I think it's just the rear. Those two bolts at rear were a b**** to take off though.
  • Replies 40
Posted Images
Yea bro its jus the rears . That will b awsum if u can help but wen we swap it over the rear will drop too low and then we hav to readjus the shock and spring. Also for it to go the oda way round the bump stop has to be removed. If u cool wid all that and no how to do it then cool odawise il have to get it done sumwere else
umm slightly confused. maybe ill speak to u soon about it. all i know is that i can take the springs in and out easily
im confused too. is it in english? :P
i think he means when you undo the rear shock the arm swings down very low. hint, stick a jack under it or a piece of wood, a brick, whatever will hold it up
anyway, if he removes the spring, it will require the height reset. which he may need assistance with.
Wat i mean is the car did not lower much in the rear and it is set to it maximum. But it didnt lower cuz t was installed upside down once we swap it over it will lower the car too much meanin we will need a height reset. Thus meanin we have to make adjustments to spring and shock. Dats how this coilover is. And we cant instal them the right way untill that rubber isolator is removed. Its like the second pic atm. But need to get it to the first
If you need to make adjustments to spring and shock, you would need to take the coilovers out again with tools we probably won't have. Looks like you might need to take it back to the shop. (Preferably Pedders Cannington if Evolution R is a problem). Also, might be a good idea to do the wheel alignment this time.
Dont take it back to the silly buggers that installed them upside down, its only like 2 or 3 bolts...
Do you still have the C spanners that cane with the kit?
Then take it to a highly recommended wheel alignment specialist.
Steve, don't go back to the idiots that installed it wrong because
1. they had no clue what they were doing in the 1st place
2. they may get aggro that it'll have to be done under warranty and do a 1/2 @ss job at it
take it to a good suspension shop ....i've used malaga suspension and wilkinshaw suspension at Bayswater before and they are pretty good. the rear suspension setup on the v35 is similar to the bmw 3 series so I think they can sort you out.
incorrectly installed suspension can be dangerous mate so take it easy till u get it fixed
gl mate
Thanx guys no dont worry im not stupid. Im taking it to My own mechanic or wilkinson suspension. Yea last tym i took it back to evolution R told him its upside down. He got one of his co workers who apparently races cars for ford racing and he reckons the only way it can go the rite way is if the bump stop is removed which will cause the tyres will hit the guards wen i go over a bump and burst a tyre. I had a massive arguement and drove off angrilly so ders no way il go bak der.
And Victor no u dont have to take out the shock at all we jus use the C spanner as Scooty m35 says.Only need to take out the spring seat assembly and remove that bump stop i dont think thats hard. Then reinvert that spring seat and make neccesary height adjustments to the adjustors on spring and shock.
Edited by CRISP 35
...And Victor no u dont have to take out the shock at all we jus use the C spanner as Scooty m35 says.Only need to take out the spring seat assembly and remove that bump stop i dont think thats hard. Then reinvert that spring seat and make neccesary height adjustments to the adjustors on spring and shock.
Ok. Well, let us know if you need help. I am on holiday next two weeks stuck at home. :)
Edited by Victor.T
i have the tools. and i can do it for him. can only do it on the w/e though. if your not in a rush steve wait for my call and we can do it this sunday.
Great.
At which place can you guys do? I was going to offer my place but my driveway might chew some bits off Steve's V. :blink:
Edited by Victor.T
Thanx guys im in no rush watsoeva. I got advised to leave rear were it is untill i get a camber kit. Cuz once we drop the rear ima have sum serious camber issues. Its a tough one
Hey just wondering for those of you who actually take your car to the track... was there much of a difference in your lap times before and after getting coilovers VS stock?
I need to do something about the camber on the front of my car and was thinking about buying some camber arms so I can dial in some more neg camber such as these Godspeed front camber arms
At the same time however if a set of coilovers make "that" much of a difference and the BC racing ones seem to have camber tops for the front it may be worth getting them. The price for them seems to be around the $1600 mark for a set however im happy enough with the stock suspension at the moment
Edited by 180 wanabe
bang 4 ur buck would be upgraded sway bars first.
Allready done and to tell the truth I dont think they did all that much, car understeered more even with the front on the softest setting caused VDC to go crazy even when I wasent understeering. So I ditched the VDC and bought some track rims with Toyo R888s which made a big difference
thats probably because the rear sway bar affects understeer more than the front.
how did sway bars affect the VDC?? they arent related!
Adding swaybars to your car can increase understeer/oversteer which in turn the will trip off the VDC if it detects that the car is about to oversteer/understeer
Im confused by how the rear swaybar could affect understeer? its linked to the rear of the car.... in my 180sx it was much easier to drift in with a whiteline swaybar set on hard compared to the soft stock one
Yeah, generally a thicker rear sway bar will make the car more prone to oversteer. As it tends to take weight off the inside rear wheel, oversteer or wheelspin (with open centre diff) is the result. Definitely going too far in one direction or the other can raise issues.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
