600hp R32 GTR 4 SALE (GM45TR)
ENGINE:
RB26DETT, TWIN HKS25/30 TURBOS, R34 GTR intercooler, Intercooler water spray,
TOMEI metal head gasket and oil restrictor, JJR coilpacks, NISMO oil filler cap,
DRIFT stainless air filters, RB20 Air Flow Meters,
GATES racing timing belt, oil catch can with drain, ARP head studs
JJR radiator hoses, 3 CORE KYOTO aluminium radiator, NISMO radiator cap,
HKS oil cooler kit with thermo fan, NISMO fuel filler cap,
PROFEC B spec 2 electronic boost controller (low boost 320rwkw, high 380rwkw)
twin downpipes 3" exhaust, APEXI power fc with handset,
2 x walbro fuel pumps, 850cc injectors, sard adjustable fuel reg with gauge
ENGINEERS CERTIFICATE FOR ALL MODIFICATIONS
quiet smooth healthy engine with great oil pressure.
_______________________________________________________________________
DRIVETRAIN:
hicas lock bar all lines removed, NISMO twin plate clutch, JJR rear cradle mounts
RWD/AWD SWITCH, REDLINE gearbox and diff oils. Rear LSD tightened up.
INTERIOR:
leather gear boot, leather handbrake boot, staged shift light,
gear knob, MINES 320 speedo, CD MP3 player,
GAUGES: Greddy boost; water temp; oil temp; oil pressure; exhaust temp;
EXTERIOR:
original SILVER respray, CARBON FIBRE VENTED BONNET, N1 VENTS, tinted windows,
WHEELS&TYRES:
17" WEDS SPORTS light weight RIMS, GTR valve caps,
Nankang NS2 235/45/17 front and rear tyres, D1 spec light weight wheel nuts _______________________________________________________________________
BRAKES&SUSPENSION:
DBA GOLD cross drilled and slotted rotors, FERRODO pads all around,
motul brake fluid, Adjustable JIC COILOVERS
FRONT and REAR strut braces, ENGINE DAMPNER KIT
AFTER MARKET SWAY BARS FRONT AND REAR
PERFORMANCE:
Dyno tuned on E85 by JEM (Just Engine Management)
OVER 500rwhp AND 950nm OF TORQUE at wheels
PB 11.05@128MPH(205kmh) 1/4 mile at WSID in full street trim with street tyres.
SYDNEY POWERCRUISE 2010 OFF STREET DRAGS FINALIST, STREET MACHINE MAY2010
MOTIVE DVD 2010 GTR CHALLENGE COMPETITOR (UPCOMING ISSUES OF MOTIVE DVD, MOTIVE TV, ZOOM mag, HIGH PERFORMANCE IMPORTS mag & FAST FOURS mag)
YOUTUBE: "GM45TR" FOR VIDEO FOOTAGE OF CAR
$29,500 negotiable*
*Negotiable items by reducing the following:
-$500 remove custom number plates (GM45TR)
-$500 remove r34 intercooler & replace with r32 intercooler
-$500 replace weds sport rims with sparco 17x9 rims (drivable tyres) or
-$1000 remove weds sport rims with d1 wheel nuts and buyer to provide own rims
-$500 remove carbon fibre bonnet and replace with factory bonnet (unpainted)
-$2000 remove power fc and replace with stock computer
remove 1x walbro fuel pump
remove sard fuel reg & injectors (replace with standard items)
reomve profec b boost control and replace with HDI unit
retune for 98 octane fuel
$25,000 with out all of the above gear
$29,500 with the lot
CALL AHMAD PH# 0421674311
https://www.sau.com.au/forums/topic/341710-600hp-r32-gtr-4-sale/
Extremely clean and quick GTR. One of the better examples i have seen!
Good luck with the sale mate, the new owner will be getting a great car.
Yeah thanx Dave, Reliablity and power dont usually come together but this beast has the best of both !
Someone looking for a 10sec GTR that drives like a stock GTR this is it !
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
