Dont suppose you have some micrometers and a dial bore gauge? I thought cast pistons with high silicon content usually run tight piston to bore clearances. Perhaps its .0014" or thereabouts...
Sorry mate, but I will give a mate a call today - he has all of this gear.
  • Replies 41
I agree with trent, it will either be too tight a piston to bore, or ring gaps. For your application, i would be running at the higher end of the specs for piston to bore, and maybe add 2 thou to the top ring gap, depending what the spec is. If any of the clearances are less than they should be, i would be asking for the machining costs back.
I'm booking the blick into a workshop today. I'll give them a list of things to report.
Hopefully they come back with some answers.
Thanks Trent and Adriano - This information is very helpful.
Sorry mate, no news yet. Work has me flat out, and I'm trying to find time to lift the block out. It's all disconnected, just need to unbolt the gearbox, and lift it out.
Are they 87mm pistons?
Still looks like a factory hone with that much lip on it, don't normally see that on such a fresh motor.
Go back and look at my thread if you can find it, exact same pictures almost and symtoms. Engine builder totally fudged the piston to bore and gave it almost double on myn.
Pulled the head off my RB30DET not long ago and when I inspected my bores they looked exactly the same as the photos you have posted. Engine buildler suggested that it wasnt scoring and was actually fuel lining the boors or something like that ... will be interesting to see what you get back from your engine builder. Mine wasn't using much oil.
Here is an update from the first inspection drop off. They are pulling it down this week, but a quick look they said:
The Deck finish was really rough - Too rough for a Metal Gasket (I have a cometic 3 layer)
The pistons could be moved A LOT in the bore - Piston to bore clearance could be shitty
No signs of over heating
Mine compression tested really well. But there are scratches in 2 bores that are too big to ignore.
Will have an official report from them by Friday, then to the next machine shop. They will inspect and then rebore & hone. Friend of mine is a qualified mechanic, build 50+ LS1s (remember the oil burning issue) is going to put it together for me. He's very switched on.
Going to get CP pistons, and Spool rods, balance and assemble. Will re-use the bearings if they are ok.
Time to go, talk soon. Hope you're all well.
if the pistons could be moved alot doesnt that mean excessive clearance?
could possibly be excessive temps causing the pistons to grow and come in contact with the bore,
so was the marks definately causing issues?
Yeah would be interested to see the condition of the bearings.
In any event I would be reluctant to re-use them. If your going spool rods then you will most likely need crank work/new bearings anyway.
i just wanted to see if they were hammered, could have been some abnormal combustion going on.
  • 1 month later...
Hi Guys. Post today is limited because we have no power. Got some pics though. Oil pump pics later tonight \ Tomorrow morning.
Sprry about the delay in getting back to you all. Took the engine to a "workshop" and they said "COme back at hteh end of the week. 4 f**king weeks later I went and got it regardless. No report written up, and wanted payment. I gave them half for pulling the motor down.
f**k some people around this town are USELESS.
Anyway.
I have a few things to report, and some pics.
1. The Pistons look normal, but with weird combustion marks. Clean on inlet side, dirty as f**k down exhaust side. Might be normal actually.
2. Pistons have 0.5 stamped on the top. Nothing else. (Pic below)
3. The Big End bearings look like brand new. No marks, no hammering, nothing. Clean as a whistle.
4. The Oil pump - Has circular marks, which look like too much crank thrust to me.
Anyway - Pics.
Edited by The Mafia
Have you had a close look at the hone patern on the cylinders? It seems to be a little all over the place. Its possible the hone is responsible for the rings not bedding in properly, resulting in a lack of lubrication that then caused cylinder gouging. Have a look for more information here:
http://www.hastingsmfg.com/ServiceTips/cylinder_bore_refinishing.htm
I was wondering the same thing - I asked for hastings rings, and if they are, then I'm thinking they may be.
And, the hone marks definitely look shit, I will bring this up during the real inspection.
  • 1 month later...
Not yet - I can't really afford to send it to the inspection crew just yet. Give me a week or two and I will send it down.
Will definitely bump this post when I get some results.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
