Car has:
New Greddy coil-overs (setup for rb) have original springs too. $1200
Full R32 rear Nismo Arm kit ( all new) $400
Front s15 (will fit r33 or if you want to widen track fit to s13 and r32 ) $250
Zenith guard bracing (extensive chassis strengthener) $250
rebuilt steering rack
Adjustable toe arms $100
Uras castor rods $200
Uras extra lock tie rods and spacers $200
Super Now tie rod ends $100
Nismo 2way 5000kms $800
R32 GTR cradle
5 bolt shafts not the weak 6 bolt
Str8 thru exhaust with twin rear bozuku flutes $150
oil cooler kit $200
Greddy 115mm intercooler ($2500 new) $600
Greddy radiator (r32 gtr) 1000 new $600
tomei fuel pump (sold) $350
Powerfc d-jetro and all sensors $1200
R34 GTT box bought with 17000kms $1500 can supply it as push or pull, currently setup as push (r33)
BLITZ twin plate (top of the range ORC) $1200
5 stud conversion, S15 front spindles, R32 gtr rear brakes, r33 front brakes, Blitz MR3 pads ($700 when new rear unused, front 80% left) whole lot $1200
whiteline sway bars adjustable front and rear $250
half cage suit sunroof $350
drift tacho and oil temp, oil press, water temp gauges $300
nardi steering wheel
vertical hydraulic handbrake with booster for one finger actuation (std still in place and working) $250
drift kevlar passenger seat with s13 rail $250
2 x sets 17x9 +15 uras ns02 all round with new toyo proxes 4 tyres $1500ea set
High Uras GT wing $200
Uras clear tailights $120
Genuine c-west bonnet $420
much much more or take the lotl for $15k or will split over the next few weeks
sad to see it go trent i loved that car =(
  • Replies 54
Posted Images
Interested in Oil Cooler kit...Does it come with Relocation kit and what brand is it?
Thanks
its all custom and has a re locator (in inner guard) core is Mspec.
Any word on my pm with buying the spoiler Trent?
gimme a day or so i have about 20 people bugging me about, im trying to figure out who asked first (as ive got it on facebook and a few other sites so i dont want to screw anyone)
^^ might also be keen on the coilovers aswell ;-)
Assuming that they come with the springs to suit a sr setup
Cheers Adrian
Yeah i got the 8kg fronts here unused, i can swap em over no dramas.
And the rears are the same?
Let me no the best price for the coils and spoiler delivered to SA 5032
thanks Adrian
Yeah rears are 6kg.
hey mate were abouts are you??
im interested in the radaitor ...what size is it??
cheers louie
0406874413
dandenong dimensions are H355xW631.8xD48 (one of the best gtr radiator's on the market) it is a full factory fit for shroud etc..
what car dose that greddy intercooler fit?? r32 gtr by an chance
Yeah it was a r32 GTR item 115mm but ive welded cooler pies to one side (see pics), just need to cut it off, simple job but ive reduced the price because its no longer buy and bolt on...
Trent its andrew with red sil80 if you can, hold the guard braces and gtr subframe till i get back from japan if possible..... but if get buyer selll sell sell!
Im too lazy to pull the braces off atm so they will most likely be there still :D
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
