  • Replies 80
Yeah it looks like trying to organise parts for others wont work, so i'm gonna chat with tony to see if his car park is still on offer and whens good for him and put the time up. then it will be byo unless someone asks me nicely :/
  • 4 weeks later...
I have setup a contact at Crows Nest Nissan, who has set up a Skylines Australia account and will give any paying SAU NSW member 15% BELOW TRADE PRICE, but you have to show him your SAU NSW Membership card.
He can order ANYTHING from Nissan or NISMO catalogs (for any Nissan).
Just to add to this. I recently needed some parts and decided to give Ivan a go. He came through in the end and bettered a price that I could get elsewhere. If you don't have access to cheap parts, sign up. The money you save on parts in the first 6 months will more than offset your membership fee. Everybody wins. :(
Thanks Andrew.
Richard
  • 3 weeks later...
  • 5 weeks later...
what is happening with this day Messiah???
this thread has been here since february and nothing has happened yet.....
can you please advise on what's happening as if it's not going to happen then it wont neeb to be stickied
thanks
Tosh
Sorry tosh, just got my court stuff sorted.... so i have a little less on my plate. i'll try and get someone done and sorted by the weekend. hang tight all.
actually... on the subject of this weekend. if we just want to have a test run we could use my property for this this weekend. reason i say test run is cos ihave only 3 concreted spaces and a fair chunk of gravel and grass. but if thats enough, cool.
if ppl think this is suitable then let me know what u all think. if its too soon then i'll get back to the board.
I'm up in glenorie aswell.
So if people can let me know 2 things. 1 do they object to it being so soon and 2 is this make shift venue ok. then its on.
  • 3 months later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
