hey guys im going to JEM tomorrow to let them take care of the cai i bought (i dont have enuf time myself to hook it up and im kinda iffy on doing it also due to afms and o2 etc and idle problems maybe) anyways, after that iv also got a 5/16 MD iso thermal plenum spacer + oem cats + ES r1-t PWR catback + y pipe, just wondering what i should expect as to my dyno readings? (iv never done any before the mods were on) anyone with the same sorta stuff on there v have any readings so i can maybe compare to?
https://www.sau.com.au/forums/topic/342690-dyno/
Might get to 170rwkw 175rwkw. Hard to tell without a before run.
Well i got 158 with fujitsubo exhaust and grounding kit
Then i put on fujitsubo y pipe, 1/2 motordyne spacer, z-tube, CIA, HFC and gained frickin 10rwkw.. pffft biggest let down ever, my car is 170rwkw, so pissed off. But it does now sound frickin amazing and turns heads all the time.
https://www.sau.com.au/forums/topic/342690-dyno/#findComment-5528743
You need to get your ECU flashed, or better still, get a NIStune board. Your AFR will be off since you've got all those mods so you need to chip it.
https://www.sau.com.au/forums/topic/342690-dyno/#findComment-5528856
Its a bit lean, but what will a flash do? who does NIStune in QLD? chip torque wants like $1600 to do it when they have the software (they dont have it atm).... They said my headers are prob holding me back. Anyone else agree? how could i only get 10kw from all of that??
https://www.sau.com.au/forums/topic/342690-dyno/#findComment-5528865
Email these guys and ask about QLD:
http://www.nistune.com/contact.php
Also, I'm not sure how much HP it "adds" but I know resetting the ECU changes the "feel" of the car (there's another thread on ECU resetting so have a look). I reset mine just before a track day and it felt a lot quicker, like someone had lightened the car and the throttle response was much sharper. Try it out, it's free and U can do it yourself ;-)
https://www.sau.com.au/forums/topic/342690-dyno/#findComment-5529203
I pull 191rwkw with Plenum spacer, Pop charger, Z tube, Grounding kit, lightweight underdrive pulleys and Extrators. Got a new Y pipe but yet to Dyno.
I guess i would get 194rwkw.
Dyno tune next... but yeah they cost a bit for little power gain.
https://www.sau.com.au/forums/topic/342690-dyno/#findComment-5529949
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
