  • 1 month later...
New PB at Wakefield!
1:09.63
Had a good day at the SAU Vs RENEW event. no breakages but the miss the splitfires were suppose to fix is still there sad.gif you could hear it anywhere on the track when did it.
i actually started looking at the dash as i was going around and noticed that the car was trying to boost over 20psi! which then the ecu was cutting ignition or something.
im pretty sure that the wastegate was staying closed as when i slowly and gently got on the power it seemed to hold boost @16psi. also a little wd40 in the top of it stopped it from happening for a lap or so it it dried out.
hopefully i have a new wastegate on soon to see if that fixes it.
next things im doing are some new tyres(the RSR's are now over a year old, with several outtings), larger sump and a VLT oil pump. wanna get traction sorted and make it more reliable before it blows lol
pic from the day :)
haha. maybe from afar it looks clean...
it started like as a cheap drift hack, slowly getting better bits into it.
Sexy daves 31 from the 31club would have to be the cleanest ive seen. but there are heaps in there to drool over :)
  • 1 month later...
Lol, moar pb umps ahead!!!!!
just bought a set of these off Syfon (pic of shanec86's car)
Sparco 17x8 and 17x9s
unfortunately, i cant afford Federal FZ201 or some slick ATM so it will be FediRSR's again, albeit an 1in wide a corner.
bought a Turbosmart 38mm gate just to trouble shoot till my new mani arrives,hopefully to the dyno soon.
thats about it for now,got to concentrate on getting the silo road worthy. rolleyes.gif so, heres some assorted picstongue.gif
and before i really did anything to it. i actually quite like hotw it looked back then
heres a vid from the SAUvs RENEW day done by Eric (Pezhead).
theres not much of me, but some really cool cars like the wide body RB S15 and a Sports Sedan R100
Watch th R34 GTR pass me on the straight. "Hmmm i might just got round the jolly old fellow" lol
Yeay!!! issue got fixed today!
cant wait for texi, two weeks till skids :)
turns out it was boost cut by the ecu. now in part to having the wrong spring and lazyness, boost has been up'd to 18psi. tune is still quite rich for some protection.
does anyone know how to convert Tractive Effort into something i can understand?
Awesome build thread, I love cheap home job builds and your two door... theyre so hard to find these days, well up here anyway.
Edited by Silvia GTR
Cheers guys, skid vids soon :)
new wheels turned up today. wider tyres and less camber/castor will help fitment, but more importantly they dont need spacers to clear brakes and they fit the hub
ring thingys.
will feel alot more confident about not shearing studs now :rolleyes:
215front/235rear going to 235front/255rear will hopefully help with grip.
  • 2 months later...
why yes good sir, i will need some good tyres.
yeay, now rolling on Federal FZ-201s!
235s and 255s
went up to wakefield yesterday and scrubed them in. felt heaps grippier then the RSR's up until 3rd gear hated life.:whistling:
8 track outings and a few dyno runs in a 20 box aint bad me thinks. got another $100 box ready to go.
also bought a GPS data logger last night, so i'll be able to keep better track of improvements in the car and myself.
quick mob pic from yesterday.
  • 3 weeks later...
so, i've had a go at making a front splitter.
its is a prototype/having a go to see if it works kind of thing. basically inan effort to reduce some understeer.
2in garden edging, 9mm ply an some s/s turnbuckels that have been attached tothe reo.
will sit flat when the bar is attached.
it sits about 100mm of the ground and goes back to the rear of the bar.
also put on the front tow point incase i poo it.
cheers champ
Well, went to the last sau day @ wakie for the year today. Good time had smiley.gif
Met Chris Easton, one of the reasons i originally got the 31, the new tyreswere awesome and the splitter actually worked!
1st session quickest was a 1:10.1, 2nd was a 1:08.7, 3rd 1:08.3 and 4th a1:07.4 grin.gif and 5th a 1:08.0..
starting to get my consistency down too, with 4 1:7s in a row in the 4th ses.
The new tyres (Federal FZ201s) had heaps of grip, way more than my old RSR'swhich were grippy as too. The splitter removed all of my understeer, defs goingto work on some more underbody aero...
And that little data logger was worth every cent. awesome to know what you did,when you did it and how.couple of quick pics in the pit
and now im going to bed as i've been up since 5....
  • 3 months later...
Done some stuff J
My missus bought me a RPM duel layer suit for my bday so I can look all pro. Unfortunately it just shows my pot belly so no pics for that… tongue.gif
I have been thinking for awhile that my spring rates are too stiff.
I've been running 10kg'sfront and 8kg rears, good for driftos not so mush for sprints.
After talking over with Blue I have put the rears in the front and borrowed some 6's for the rear off Sweetfu
And my cf bonnet from fatz showed up last week. Quantity so awesome I crack an instant boner
Truth be told, I've wanted a 31house bonnet since I got into 31's… nearly 11years ago!
Also bought some flash aerocatches
They go here
Marking out
The scary part
How flash is that
Bolted to the hinges
After my last Wakefield day the FZ's showed how under braked my car is so now I've had some dogbone brake adapters made up and am just waiting on a price for some project Mu 330mm disc's for the front.
see, 31s can look low...
Where did you get the brake adapters made?
Also on your splitter, do you have any pics please showing how you attached the ply to the garden edging? I'm guessing 90 degree alloy edging cut into small pieces
love ya front diffuser. if it works let me know we can get copys made of carbon. lol
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
