for those plugs, you should leave them at 1.2mm unless you are getting a miss at high boost. The bigger the gap the better the burn, people only gap them down when the spark is not strong enough at high boost.
good idea to check stuff out early....can't say I've ever tried that :wacko:
  • 1 month later...
So, my EOI entry for WTAC has been accepted smiley.gif guess they need some back markers to liven things up haha
Have some work to do in the next few months to bring it up to standard.
Can anybody tell me what the lowest weight "manufacturer's original specifications" for a HR31 is? Im allowed to have upto 15% less than that.
Got started on the weekend. As im going to be very under powered in open, my goals are;
-make better use of what the car already has
-make the car as reliable as I can
Plans so far…
I don’t really want to pump any motor power through the motor as isn’t a built motor and I don’t have the cash to build one between now and then, So ive ordered a few bits and pieces like 25% under driven balancer and lightweight flywheel with arp bolts to free up some power. will aslo be getting retuned as well
I have a 9l gated sump to go in, heat shields, new wastegate diaphragm and lines, new turbo beanie as the last one is falling apart.
Spare exhaust manifold (old has cracked again) Im redoing the exhaust (this time side dump and screamer) to clear up the back end for the diffuser and save a bit more weight.
getting ready to pull the motor. also sort of how the exhaust will sit, basically just flipping it over cutting the end off and adding a bend to go out the side.
The splitter and side skirts are going to be dropped down to around the 70mm height rule, just with sheet alloy. Wont look pretty but should help.
The hydro is going too, as It makes bleeding a bitch.
Front guards have been spaced out 30mm help stop wheel well turbulence, don’t know if it’ll work but looks cool tongue.gif and i'll be making some bracing for the engine bay/firewall here too.
Was pleased to see little/no rust
Bum cut out
And Ive bought a spare set of axles of Tir31 biggthumpup.gif just in case.
Got a little done on the weekend.
Putt the fittings put on to the new sump and fitted the ignition cut off cable. I’ll get some pics later..
Bit of weight reduction…. Im tiding up the bay while the motors out, bit of paint, fixing up some wiring and general messiness.
Cut out the radiator support panel for ease of removing the motor, knocked up a new one and some air guides for it too.
Not finished yet but you get the idea. Need to do something for the top of it too.
Old vs new flywheel
Im also going to put on some 25 cam covers I have, and am tossing up wether to paint them red again or black. or yellow. lol any votes?
boat anchor
Well, im feeling quite loved atm :) Fatz the top bloke he is has started a thread to help me get to WTAC. And so far has raised a heap of the folding stuff, help and even a sponsorship deal with Australian & Japanese Dismantlers for a set of tyres.
This has really taken huge burden off me and I am really grateful for the generosity shown by the members of this club, Thanks heaps everyone! :)
Engine bay degreased and a lick of paint to make it feel pretty. New cam cover gaskets have rocked up today, so tonight I’ll prep and paint the 25 cam covers.. the extra volume should help keep a bit less oil making it to the catch can.
I put on the modified sump (think its about 8l with gates) and new balancer (which is tiny). Also a new timing belt and tensioner while I had easy access.
Just waiting on one more fitting for the new head drain hose, then I’ll slap on the flywheel and put it back in the car.
Ok, I have a little question.
My current exhaust manifold has cracked (again) and I don’t really want to re-weld it.
I have two options, either buy another and keep the same setup or use a Twin Scroll manifold (has two old HKS wastegates) that I already have but will need to buy a new turbo housing for.
It should be about the same cost, just a little more work to go T/S
The turbo is T3 atm and the T/S mani is T4
What are peoples opinions?
I would put a steam pipe single scroll mani on it. Your putting in a lot of effort to make the event, would be a shame to have a thin wall ss manifold crack or old waste gate fail on the day. TS would be nice but it comes at a cost.
I have decided that the money from the donations will all go towards tyres. I'll do a sexy poise on them when i get them :)
This has freed up enough money that i was able to replace the manifold rather than weld up the cracks again.
Its a one of the Mild steel jobies from Hybrid in NZ, the quality is actually pretty good (better than the chinese one) I didnt get a pic but its all smooth in the collector and the face of the flanges (thick too) a straight. It puts the gate futher away too, which i think will help with the diaphragm issue.
Also rerouted the water return, put the new beanie on and have use silcon hose for the wastegate.
New oil drain from the head to sump
I have also finish painting the new cam covers. dont you judge me...
YELLOW!!!
I think it'll look good in an all black engine bay. Ive painted the strutbrace and boosted stopper i made black so they dont stand out too much.
I'll put the flywheel and clutch on and hopefully have it back in the engine bay this weekend.
What do people think of Royal Purpal oils? thinking of trying them as im a sucker for advertising
What do people think of Royal Purple oils? thinking of trying them as im a sucker for advertising
I've used all the top oils, even the $50/l stuff and they all effectively work the same....basically none of them provide significantly better protection and performance than each other.
Obviously use synthetic, change it often, and make sure it doesn't get too hot. But don't worry too much about which brand
ok, no worries. cheers man
thanks guys, the CAS isn't polished. its a modified one thats been ceramic coated inside and out. i was given it a while ago, but haven't been sure how to setup the Vipec for it (has 32 hole wheel). ESP's job :)
been meaning to get back out there for awhile now. but, yeah after s/l
will be interesting to see time difference, it was my first trackday with the 30 (220kw) and reallllllyyyyy old 225 wide 595RS's.
got a bit more done on the weekend
Motor back in
guards are back on too, and have been spaced out.
not sure how much benefit there will be for a box shaped car but it didnt cost anything and hopefully will help.
kinda cool without a front on it
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
