ok i have an RB20DET in my ride as we speak
was thinking about running some mods on it
or upgrading to an RB25DET or RB25DET-NEO what you think
whats the pros and cons with the RB20DET, RB25DET & the RBB25DET-neo
currently my rb20 is running
*Stock rb20 motor
*300zx 45v3 t3 turbo
*10-12 psi boost
*TurboXS boost controller
*Blitz bov
*Blitz LM 3" intercooler
*2.5 intercooler piping
*3" free flow stainless exaust
*Custom RB26 side mount intake manifold
*Upgraded ecu ( flashed\remapped )
*Fidanza 4.3 ceramic clutch kit
*NGK iridium spark plugs #7
*Walbro external fuel pump
Was going to upgrade to......
*Rebuild with Genuine Nissan complete engine kit
*Genuine nissan piston rings
*Garrett GT3076r or hks GT3037pro-s
*Xo2 exhaust manifold
*Sard fuel press reg
*550cc injectors
*AEM water/meth injection kit
*Greedy E-manage ultimate or haltech unit (TRY TUNE TO ABOUT 18-20PSI)
*Map sensor setup
*Wide band o2
*Cometic metal head gasket
*ACL race bearings
*ARP head bolts
*HKS timing belt
*Oil cooler
*Oil rerun lines from head to block
  • Like 1
https://www.sau.com.au/forums/topic/342842-rb20det-vs-rb25det/
Really depends what your goals are. How partial are you to your RB20?
Usually in these circumstances it's easier to drop an rb25 in. By keeping the Rb20 you'll always be behind the '8 ball', given that the extra 500cc is a 25% increase over the stock rb20.
Depending on your power goals, I'd personally take a rb25 if you can do it cheap enough.
Edit: was also going to say I hate mods going to waste. But a lot of yours could be applicable to an rb25 set-up. Now is as good a time as any to make this decision. Before you spend money for specific rb20 components
Edited by Truffles
Factory RB25 you can do 280rwkw safely (about the limit IMO).
A RB20 @ this power level will be quite laggy, however the RB25 isn't "too" bad. Its basically where the compromise point is.
But as asked, depends what you want mate.
Use of car? Motorsport? Response required? Drag? what? :verymad:
As stated, it really does depend on your goals. There is a thread I think all RB20 owners should read before giving up on the motor.
http://www.skylinesaustralia.com/forums/Bo...20-t330619.html
Personally Im not an RB25 fan boy. I think the lag limitations of the RB20 keep it grounded as far as usable and reliable power goes. I personally am a fan of Roy's results, and I think a 260rwkw RB20 with delivery like his would be an excellent motor.
Maybe consider going down the TD06 route before you give up on your RB20, at the end of the day you can transfer your turbo kit over to your new motor should you decide to go RB25 later.
More TD06 info here:
http://www.skylinesaustralia.com/forums/Le...tml&hl=td06
get a 25 you will never look back, it is sooo different to drive, more low down power, can make more power before getting laggy and even then you still have more off boost capacity so it isn't as bad.
VCT is a godsend and makes it so much nicer to drive as well, I would never ever get an rb20 again, they sound amazing but that is it, I think I'd go an SR20 before an RB20.
Ive had 2 rb20s and 1 rb25 with a highflow turbo and the difference is night and day.
If you have an R32 you can reuse half the stuff anyway, intake etc, use the rb20 ecu and get a nistune module, eboost street so you can retain the VCT and you can use all the old sensors, means you don't need a half cut, just the raw motor, might need to change a few things like throttle body but that is it.
Edited by Rolls
yeh i dunno about this personally i think rb20's are highly underrated and very usable up to the 250kw range, i'd never remove a running one for a 25.
when my last rb20 blew a headgasket i went engine hunting, i already had a rb25 box in the car so i got a rb25 engine cheap and dropped that in.
now both of these engines were running stock turbos with 1 bar of boost the rb20 would be around 160kw and the 25 was making 193kw.
the 25 was a decent upgrade but if i had a 25 turbo on the 20 i dont think the gap would of been all that great.....
i also think its crazy to rebuild a perfectly good running engine but if your deadset on doing a rebuild i'd be looking at a 25/30 build for the 3L's of fury!
peak power may be similar but the 25 will be much quicker on the street.
imo, get yourself a 32 25de head, bolt it to a 30e block and throw on a gt30. can re use all your silvertop loom etc that way and nistune the ecu
below 200kw the difference isn't that much, but when you get closer to 250kw the difference is massive, drive both and you will see what I mean, an rb25 making 250kw has more punch down low than a stock rb20, it really is night and day.
300rwkw on an rb25det won't last very long...
many cars on here say otherwise...
i've been running ~300rwkw for almost 2 years now on stock internals as have a heap of others
Unfortunately the OP is in Trinidad/Tobago and they don't have RB30E's over there.. I've been telling him to build a 30 for ages ;)
whats your reasoning for this? i beg to differ. in fact if u ignore the pistons for the most part, 25 and 30 internals also a farely strong. u may drop a bearing at 300kw but thats due to the fact they are old and f**ked anyway.
and to be honest i havnt seen too many problems with the 25 pistons its usually the australian 30et pistons. (stock vl turb pistons had a tendancy to 'melt' lol)
not having a dig just curious. you may have seen some fail and i just havnt come across it yet.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
